Old 08-03-2011, 03:58 PM
kentster is on a distinguished road
Parker HZR100 for large scale machine Z axis?
I have 2 Parker HZR100 vertical actuators mounted on 100mmx100mm Parker extrusions (1524mm and 1828mm in length respectively). Both are equipped with Mitsubishi HC-SFS152BK 1.5KW servos.
http://divapps.parker.com/divapps/em...talog_engl.pdf
Would this system be well suited for someone building a large scale overhead gantry router? I'm personally at a loss as I don't have an application for them presently.
[/URL]
Need A Quote- Looking for a large scale Fabricator MVJKstudio Employment Opportunity 0 08-05-2010 02:03 PM
Heavy large scale gantry mill/router/3d carving 5 axis build Tristar500 DIY-CNC Router Table Machines 20 03-18-2010 06:07 AM
Machine for 3D Yacht Scale Models? ezemiodyk Want To Buy...Need help! 1 05-06-2009 01:34 PM
How Does One Get the Machine Scale to Equal Mach2' TheNigerian Machines running Mach Software 5 05-08-2006 03:03 AM
seeking input on large scale-up of toy dberndt General Metalwork Discussion 22 01-12-2005 06:27 AM
