Old 08-02-2011, 10:03 AM
rbs rbs is offline
rbs is on a distinguished road
Ball screw bearings refilling DIY
Hi guys,
I was very interested to find out what would happen if i unscrewed the nut from the screw and found out several months ago what would happen.
Thats right the bearing came flowing out, I managed to collect most of them with a magnet but then measured them and got some back up ones incase i didn't collect them all from
Simply Bearings Ltd ~ Oil Seals SKF FAG TIMKEN KOYO NTN NKE TRULOC Needle Rollers Taper Rollers Rod Ends Oilite Bushes Loose Balls O Rings Grease Plain Thrust
now comes the tough parts.
Chia from linearmotion who i bought the kit from has given me a rubbish tutorial on how to refill to my knowledge and doesn't make sense.
I know people have done this before so can any one visually describe how to properly refill the the nut.
Need opinions on BP ball screw bearings Dwane Bridgeport and Hardinge Mills 17 07-14-2010 08:06 PM
Need Help!- Bmc ball screw support bearings JWC HURCO 7 09-27-2008 09:56 AM
Attaching bearings to a ball screw ranchak Linear and Rotary Motion 5 09-22-2007 12:01 AM
installing ball screw bearings dgalaxy Bridgeport and Hardinge Mills 12 09-01-2006 09:06 AM
Ball screw without bearings? Halfnutz General Metalwork Discussion 6 06-13-2005 03:10 PM
