Old 08-01-2011, 05:30 PM
ssutton is on a distinguished road
Exploding TrueText to dxf
Hi All,
I am in the middle of a sign job and I have noticed when I cut large (10 inch) letters that there are noticeable segments along the arcs in the letters that are composed of strait lines. I know that this is coming out of my CAD this way (TurboCad 17) when I explode it. I can sand them out but I would like a software that could explode them with true arcs. I downloaded Outline Art but it keeps locking up my computer, however it did run long enough to export the test and they looked great when I viewed them in CAD. Also, when I try to go to the website to pay for the software I get a URL error.
Does anyone know of a cheap and effective software that will explode standard text and make an arc component DXF file?
[ATTACH]Click image for larger version
Thanks,
Scott
Old 08-02-2011, 10:27 AM
Gold Member
RomanLini is on a distinguished road
CorelDraw should do it. You can create the text char and then "convert to curves" which makes it a graphics object.
At that point you get a lot more control over the curves and nodes etc.
Maybe your CAD program also has an option to convert the text object to a "graphic" or "2D curves" object?
Old 08-02-2011, 08:41 PM
tpworks's Avatar
tpworks is on a distinguished road
TC17 will only convert to curves after you explode the text, it does fine on letters without islands like an "L" or "l" but a "g" or a "p" gets distorted.
...He who makes no mistakes makes nothing! ...
Tom
Old 08-04-2011, 05:01 AM
CNC-Joe is on a distinguished road
There is a guy that offers a program to do this - TTFtoDXF - his name is Andrew Clayton, and his website is:
Gcode2000, TTFtoDXF
I believe it still operates for serveral days in a demo mode, but he wants $100 for a registered copy of it.
I'm interested in finding any freeware routines at doing this.
JoeComunale (at) Comcast.Net
CNC Is Not Just My Passion.. It's My Addiction !!!!
Old 08-04-2011, 09:27 PM
tpworks's Avatar
Here is a freebe I found back in the 90's suprising it is still available.
DeskNC
Tom
Old 08-05-2011, 04:29 PM
DMF_TomB is on a distinguished road
Text fonts converted to lines and arcs
an old Autocad method
1) select text and use WMFout and save this file
2) use WMFin to put this windows metafile into AutoCad
3) then when this is selected and Exploded it should be individual lines and arcs
Autocad has ability to export and inport Windows WMF files. Some generic Cad programs do not have this ability.
Exploding Arc-Aligned text Drools Autodesk Software (Autocad, Inventor etc) 14 06-16-2010 09:24 PM
exploding capacitors in RPC laniak Phase Converters and VFD 7 06-05-2010 10:36 PM
Danger: Exploding Capacitors Eurisko Stepper Motors and Drives 16 03-01-2008 10:48 PM
"exploding" an entity? YARKONE Mastercam 2 10-29-2007 08:42 AM
Exploding drawings Hack TurboCAD/CAM 1 02-27-2005 02:49 AM
