Old 07-30-2011, 11:17 AM
Eddymeister's Avatar
*Registered User*
Eddymeister is on a distinguished road
Talking Design and Build
New machine I'm currently underway with...
This is my first but I've been an avid CNC spectator for some time now...
The machine will have a foot print of 1220x 1800... Still needs a little refining but I'm fairly happy with my design...
Comments and expertise welcome...
Name:	CNC Router 1.jpg‎
ID:	139131   Click image for larger version
Name:	CNC Router 2.jpg‎
ID:	139132   Click image for larger version
Name:	CNC Router 3.jpg‎
ID:	139133   Click image for larger version
Name:	CNC Router 4.jpg‎
Name:	CNC Router 5.jpg‎
Old 07-30-2011, 06:31 PM
PaulRowntree is on a distinguished road
Congratulations on the start! What materials will you be using to build the gantry supports? What is the Z range?
Old 07-31-2011, 03:29 AM
*Registered User*
Talking
Hey Paul...
Thanks on the congrats... I've been an avid spectator for far too long... Time to play...
I've chose a solid aluminum construction... Basically its all constructed of Aluminum PFC... An Extruded beam...
The main X Axis will be supported by 150x75mm PFC's and the gantry itself out of 200x75 PFC...
Rigidity and accuracy is what I'm aiming for...
Its very simple too... Only about 20 parts in the total structure...
I'll send the PFC's out and get ways machined into them and at crucial intersections then bolt it altogether...
As it stands
X = 1820
Y = 1220
Z = 120
This will allow me to cut 1200x1800 with a 10mm bit for a maximum cut...
Fingers crossed it'll work...
Stay tuned...!
Name:	CNC Router with stand 1.jpg‎
ID:	139170   Click image for larger version
Name:	CNC Router with stand.jpg‎
Old 07-31-2011, 08:40 AM
acondit's Avatar
acondit is on a distinguished road
Actually it should allow 1210mmx1810mm. You only lose 1/2 the diameter at the limits, so cutting both sides you would lose 2 * (10mm/2) or 10mm.
Alan
http://www.alansmachineworks.com
Old 07-31-2011, 09:34 AM
*Registered User*
I allowed a little extra built in as I've still yet to receive the specs on the linear bearings I'm looking at...
The z axis needs some more refining... It may end up a little wider thus reducing the cutting area...
I'll probably jack it up to and increase the overall length as the extra height between the bed and the underside of the gantry will probably be benficial when raising the work peice off the bed...
I'm currently ordering parts in for the controller... Refining my design as I wait...
I'm awaiting a response from PMDX in regards to their 126 bob and 133 gecko bob... Steve Stalling from PMDX mentioned they are revising their 126 bob to enable slaving... The more I read about their boards, the more I'm impressed by them... It sounds like they are well versed at industrial retrofits using their own boards...
I'm a tradesman so I have a certain tendancy to ensure everything I purchase is of industrial standards...
I'll be looking into a Super PID router controller in conjunction with a PMDX 107 till I scratch up the cash for a true spindle and VSD...
I've got my motors and 3 gecko 203V's with another 2 on their way... Keling Inc are shipping the 50V 20amp unreg power supply...
With the aussie dollar doing so well its making it cheaper... But talk to me when its up and running... Heehee... But I got the geckos for 85AUD... Pretty sweet.... Considering the retail for $150ish... Hence upping to PMDX Boards rather than the cheaper ones...
Anyways...
Old 07-31-2011, 09:44 AM
ger21's Avatar
You don't need the PMDX 107 with the SuperPID.
2 output pins from the parallel port will give you on/off and rpm control for the SuperPID. I control my SuperPID directly from the parallel port, without even using a breakout board.
Old 07-31-2011, 10:03 AM
hjcraver is on a distinguished road
I am new to Forum , just joined yesterday, and am impressed on how much help and knowledge is accessable. You design looks great. My only comments are I prefer a steel subframe for weight and rigity. You may want to look at some of the Chinese machines (Ebay and the internet)for ideas such as the Jcut 6090B or DW-6015 machines . Theirs has a cast iron base and are very cheap to import. It is very cheap to build a 2/ 2-1/2" tubing frame to have a very rigid frame to mount your Aluminum components to. The top could be a 12ga. or so steel 48" x 96" plate with all the necessary mounting holes cut off a laser.
I dont quite understand your guide system but I would recommed using no less than 25mm sq. guide hardened rails and linear bearings . These are very cheap these days and I recommed Automation Overstock, surplus automation equipment, overstock automation devices, manufacturer overruns, linear bearings, variable speed drives, circuit breakers, contactors, starters, relays . You wont believe their prices on Hiwin HD Rails.
If my comments dont make sense to you application its mainly because I am new to the current designs or CNC Routers. Good luck. Hubert, North Carolina
Old 07-31-2011, 10:12 AM
*Registered User*
I had considered this at first and running the Super PID straight from the 126... I'm no electrician but the 107 provides an isolated source... I don't know if its smart choice... But figured trying to consider future upgrades... VSD and Spindle...
I wanna try and future proof it...
Hence Keling's larger powersupply for future axis's
Considering postage to Australia is the same as the cost of a 107 I thought id get it along with my other purchases...
Plus itd look cool... Hehe...
Old 07-31-2011, 10:26 AM
*Registered User*
Gday craver...
Welcome to the forum... Thanks for your comments... I really haven't settled on the base of the thing at the moment... I drew up that cabinet under it as an idea...
I agree, a steel frame will probably be the go under the machine... Probably something in the vicinity of 2.5"x2.5"... When will you US guys convert to the metric system...!!! Give up your wicked ways... Haha
I'll definitely check out your link tho... Cheers for that...
Im a bit dubious about the Chinese machines.... I think building it will be half the fun and challenge... Cast iron would be great but considering my circumstances would be a pain in the ass...
Cheers for your thoughts...
Old 07-31-2011, 11:07 AM
I am a Q.C inspector for Industrial and Laboratory Furnace and Oven Manufacturer | Thermcraft Inc. and I use metric but our shop standard is Mr,Dewey.
Just for dreaming look at a few of these base suppliers . I agree with you the fun is designing and building. See Ya.
http://www.americangrinding.com/divi...akesbases.com/
Durant Tool Company :: Online Catalog : Machine Bases
  #11   Ban this user!
Old 08-04-2011, 05:18 AM
mkc2's Avatar
mkc2 is on a distinguished road
Looks like a nice clean build, can't wait to see some real action with pictures.
Will be watching your progress, hope it all works out ok, there's plenty of guys on this forum to help you out.
Cheers mkc2
Old 08-06-2011, 01:02 AM
*Registered User*
Question DEsign Aspects...?
Its been a while since i last posted... I'm still designing...
I have a quick query for anyone out there in the realm of design willing to comment...
How much clearance would be adequate between the bed and the underside of the gantry...
I suppose this comes down to the sort of work I'll be doing... However... Too tall equals less rigidity and less accuracy... The lower the gantry is to the bed will make an increase the machines rigidity and accuracy but will limit the machines ability for certain things...
I do intend on creating a 4th axis that can be turned 90 degrees for turning as well as rotary milling... Kinda like a CNC Converted Vertex Rotary Table with a chuck...
I just want to get some ideas off those guys who have come across this in their machining and if they were "to do it all again" approach...
Comments greatly recieved...!
new to DIY CNC. want to build. have question about best design. mkyle DIY-CNC Router Table Machines 16 02-17-2011 02:02 AM
Newbie- First Build: Looking for comments on my design brianrumburg CNC Wood Router Project Log 16 02-24-2010 10:04 PM
Newbie- Can I design and build a CNC Router!? morgandhunter DIY-CNC Router Table Machines 17 10-13-2009 02:49 PM
Engine Design & Build gbowne1 I.C. Engines 15 02-26-2008 02:59 AM
What CNC design did you build first? soundmotor DIY-CNC Router Table Machines 2 04-28-2006 09:05 PM
