Old 07-26-2011, 02:30 AM
ssutton is on a distinguished road
Rotating nut design out there?
Does anyone know of a workable rotating nut (acme rod/anti-backlash nut) design that has been tested and proven for a CNC table? Thinking about machine #2 already.
Thanks,
Scott
Old 07-26-2011, 10:02 AM
acondit's Avatar
acondit is on a distinguished road
Look at the rotating nut that I built for my X2 conversion (posts 4 and 5). It uses a ballscrew and rotating ball nut but the principle is the same. All you would have to do is replace the ballnut setup with a mount for the anti-backlash acme nut. You could use a smaller diameter timing belt pulley if you wanted.
Alan
ID:	138911   Click image for larger version
http://www.alansmachineworks.com
Old 07-26-2011, 10:35 AM
ger21's Avatar
This machine uses a rotating nut.
http://www.cnczone.com/forums/diy-cn...mentation.html
Old 07-26-2011, 01:53 PM
Phife is on a distinguished road
I cant find a reference to the rotating nut on that link, you sure its this machine?
Old 07-26-2011, 02:02 PM
prcdslnc13 is on a distinguished road
its not in that link but it is that machine. If you google the name of the machine it will come up.
Old 07-26-2011, 04:27 PM
ger21's Avatar
http://www.cnczone.com/forums/860630-post92.html
There's some info about it in a previous post in the thread, but the pictures from that post are gone.
Old 07-26-2011, 10:12 PM
cyclestart is on a distinguished road
Another recent spinning nut design
http://www.cnczone.com/forums/diy-cn...nc_router.html
Not an anti-backlash design but the builder thinks it would only take a small design change.
Anyone who says "It only goes together one way" has no imagination.
rotating lead nut design homer93 DIY-CNC Router Table Machines 17 05-18-2011 10:14 PM
thoughts on rotating nut design (acme) johngalt47 DIY-CNC Router Table Machines 20 05-11-2011 09:14 AM
Rotating Nut coop2005 CNC Wood Router Project Log 32 05-10-2011 12:15 AM
Build Thread- rotating nut design johngalt47 Open Source CNC Machine Designs 3 07-15-2010 05:38 AM
Rotating JWB_Machining Mastercam 14 12-02-2008 06:33 PM
