Hi. first of all, I apologise if this is in the wrong section. there seems to be a plethora of categories and I simply don't know which is correct! I'll keep this short and sweet! I want to engrave words onto metal and I am told that this machine would do it: Click here So, i bought this machine and it arrived a few days ago with a dodgy Cd and a few bits. I've managed to load the artcam pro software and put the machine "together". However, I am now stuck and it's driving me absolutely crazy. I assumed the software would be quite simple (I have a laser engraver which runs off coreldraw and I simply type what I want and press "go"!) - this doesn't appear to do that. So - can someone give me some much needed help please. all I want to do is engrave small metal objects for some trophies. But I don't know where to start. I can get as far as typing the words, but how do you send it to the machine??? (sorry - I realise I sound dumb!) Any help would be hugely appreciated!!! Thanks |
| It looks like it should work out of the box? So what software and operating system did they include? Al.
| Artcam is your problem, its a extremely complicated program. Why did you buy it? its very expensive and made for 3D work, not engraving. Get something like Vcarve Pro, I use that for all the Stainless steel engraving I do. Works great and very easy to learn and use. |
| I'm sorry to say this, but a CNC is nothing like a printer, it's way more complex to operate and needs some knowledge about what's going on and what you can and can't do. Artcam can not move the machine by itself, you need a controller software to open the toolpath file generated by Artcam. Most people use Mach3. Kcam is another nice software you can use that is a little more user friendly than Mach3 for people who are new to CNC. Watch some Artcam tutorials on YouTube, read A LOT not only about Artcam but about CNC as a whole (CNCZone is probably the best place to start reading), and do a lot of simulations before you try to actually cut something, because it's very easy to damage your bits and machine if you don't. Artcam has a "?" sign that enable extra information about some options like toolpath generation. You'll also need some information about the machine itself to configure the controller software (screw lead, pinout, active low/high, acceleration/speed and other stuff), info that SHOULD be provided by the machine's seller. |
| The way I read the ad, it seems to imply that the operating S/W is included, if so maybe you need to know how to download a file from the CAD to the controller and then run it? Al.
It probably is behind the gantry, (there's something that looks like a reduction pulley cover) the first image doesn't show anything but that seems to be a completely different machine. |
#10
| Sorry but I think we need more to go on Can you offer a screenshot ? (you may not be allowed attachments with only 3 posts ?)
![]() Artcam creates (posts) a gcode text file and your ebay purchase claims to read these type of files. Gcode explained; G-code - Wikipedia, the free encyclopedia Maybe you understand this part but it's not clear from your post.
__________________ Anyone who says "It only goes together one way" has no imagination. |
#11
| If you have already purchased Artcam, you do not need to buy another program like V-Carve (in my opinion). Not trying to get into an argument with others with different opinions on here, but it will generate engraving toolpaths just like V-Carve. Granted, it is more complicated than most of Vectric's software and probably better suited for 2 1/2 and 3D equipment, but there is a learning curve with all software. Spend time learning and researching. Do the tutorials on the Artcam website. You'll get there. |
#12
| thanks for the advice... Right, i am starting to get to grips with the theory behind this. Ok... so Mach3 controls the machine, is that right? Anyway, I've spent ages on this and have managed to sort out the "ports and pins" settings in mach 3 and have loaded a sample g code. i then press start and the machine doesn't move at all. it runs through the code and the image shows the various stage of the cut (it's a very simple square shape) All I want to do is make the machine move! I think that once I can be assured that the thing is moving. Anyone any ideas about what I should be pressing to make my machine spring into action? I'm sure it's a really simple thing, but if anyone can give a step by step "idiots guide" i'd greatly appreciate it! The machine is a Redonda... cheap chinese rubbish probably! |
| SIM-homing question (warning dumb newbie) | 40fordcoupe | LinuxCNC (formerly EMC2) | 1 | 11-02-2009 06:33 AM |
| Pull Studs on CAT-40 - Basic Stuff | JWB_Machining | General Metalwork Discussion | 4 | 11-27-2008 06:48 PM |
| Lot of Basic Questions from a Newbie | mvadu | Benchtop Machines | 10 | 06-18-2007 08:53 AM |
| Hello All... I'm A Total Newbie 2 The CNC Stuff. | deejayehn | CNC Plasma and Waterjet Machines | 21 | 04-07-2007 09:21 AM |
| dumb questions maybe, I'm I newbie | wedge | General CAM Discussion | 8 | 02-19-2004 01:10 PM |
