Old 07-20-2011, 08:55 PM
ItzAllGooD is on a distinguished road
Threaded inserts for MDF
Has anyone used threaded inserts instead of trying to thread MDF. I thought about just using epoxy and regular nuts. Think JRGO pipe adjustment blocks. Any luck?
Old 07-20-2011, 11:17 PM
acondit's Avatar
acondit is on a distinguished road
I just drill the hole to tapping size, squirt a bunch of super glue in the hole, let it set, and then tap.
Alan
http://www.alansmachineworks.com
Old 07-21-2011, 06:02 AM
ind_dsnr is on a distinguished road
McMaster Carr
Try these: McMaster-Carr
If you need the back side of the t-nut to be flush with the surface of the board, you can use a spade or forsner bit. These are great and I use them all of the time.
Name:	mcmaster t-nut.JPG‎
Old 07-21-2011, 08:33 AM
frige is on a distinguished road
Look up 'dowel nut' on mcmaster also.
That might fit the bill, depending on what you are trying to do.
-frige
Old 07-21-2011, 10:54 AM
jsheerin's Avatar
jsheerin is on a distinguished road
I've used the threaded inserts as well as t-nuts. I'm not a fan of either. My experience with the threaded inserts is that they distort the MDF when you screw them in and then can still start turning. I also broke some. I ended up epoxying in the ones I was using after I had them installed. This worked, but it was a pain. The best setup I've ever used for threads in MDF was cutting pockets for regular hex nuts to lightly press into and then epoxying those in.
CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
Old 07-21-2011, 03:46 PM
ger21's Avatar
I think the dowel nuts are the easiest method. An alternative would be to epoxy coupling nuts into the MDF.
Lathe - threaded hole/threaded pin, not concentric when bolted together!? The Aspirator General Metalwork Discussion 13 04-17-2010 11:28 AM
Ceramic Inserts Hellbringer Mini Lathe 1 06-30-2009 08:34 AM
Newbie- What is the difference on 321 inserts?? wrechin2 General Metalwork Discussion 13 01-18-2009 01:15 AM
How Inserts are made? Wiseco General Metalwork Discussion 15 04-13-2007 08:54 AM
Ceramic Inserts Turbine CNCzone Club House 2 09-24-2003 09:23 PM
