Old 09-16-2005, 06:43 PM
tomcook is on a distinguished road
power source
hi all im confused as to what sort of power supply i should use
to run a hobbycnc 3 axis driver and 200oz/in steppers from the hobbycnc web page
a 24v pc power supply or what else can i use ?
i want to get the best performance out of them
cheers
tom
Old 09-16-2005, 07:17 PM
sol sol is offline
Gold Member
sol is on a distinguished road
He (Dave, HobbyCNC) recommends a couple and gives links on his site but some of us made ours out of old microwave transformers. The rewinding is not too difficult if you're not a stickler for appearances. Bubba tells how here:
http://www.cnczone.com/forums/showpo...1&postcount=14
Old 09-16-2005, 08:10 PM
ger21's Avatar
cheers
tom
Use a 36V power supply for best performance.
Old 09-16-2005, 08:23 PM
Ursine is on a distinguished road
The Hammond 30vac xmfr Dave recommends will give you about the max voltage the board can handle (30 vac x about 1.4 for going thru the ac/dc conversion = 42-44 vdc. The board handles 44 vdc max).
Dave
