Old 07-20-2011, 11:12 AM
adt2 is on a distinguished road
How to cut / machine Acme rod?
I'm in the planning stages but also ordering supplies for my upcoming build, and I need a little guidance re: Acme threaded rod.
What sort of machining needs to be done to the rod itself prior to use on these machines? Obviously it needs to be cut to length; is there anything else to be done before use? If so, is it something I can do, or am I gonna have to hire it out? For what it's worth, I'm going to be using the 1/2" Shaft Adapters and the Bearing Blocks from CNCRouterParts.com.
Thanks in advance.
Old 07-20-2011, 03:07 PM
DonFrambach is on a distinguished road
I did not machine the ends of the acme leadscrews on my machine. On one axis, I used couplers from DumpsterCNC.com for the other two, I used couplers from CNCRouterParts.com. Both worked fine.
Here's a photo of the DumpsterCNC.com axis:
Old 07-20-2011, 03:14 PM
oops. Didn't upload the previous picture properly. This one is better:
Old 07-20-2011, 03:15 PM
From what I can tell from the exploded view on the CNCRouterParts.com site, it looks like one end of the Acme rod goes into a coupler, and the other end goes into a bearing block assembly.
What led me to ask this question was the sales pitch over at FineLineAutomation.com, where they offer the Acme rods "pre-cut and with chamfered ends to make loading the LeadNut much easier." I was all of a sudden afraid I was going to have to spend countless hours making a perfectly clean cut with a hacksaw and then cleaning up the threads with a tiny file or something.
Old 07-20-2011, 03:28 PM
You do need to clean up the burrs with a file or a grinder. But a very rough job will do the trick. Something like 30 seconds of work.
Here's a photo of what I mean:
Name:	ACME screw end.jpg‎
Old 07-20-2011, 03:43 PM
Another thought. I cut my ACME leadscrews with a cheap abrasive saw rather than a hacksaw.
Old 07-20-2011, 04:36 PM
I can probably spare 30 seconds.
Old 07-20-2011, 05:22 PM
CarveOne is on a distinguished road
Not being the precision machinist that I would aspire to be, I cut mine with a hacksaw or my metal cutting band saw then square off the end on my 12" 80 grit disk sander, then twirl it a turn or two at a small bevel of about 45 degrees against the disk sander. If you leave it squared off, it will be harder to start in a delrin anti-backlash nut, but it can be done. If there are dings on the tops of the threads it won't slide into a bearing without locking up. Protect the threads while clamping for cutting.
Cheap ACME rods may have burrs on the thread tops. Those can be lightly block sanded off with 400 grit sand paper and then final polished with 600 grit.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 07-20-2011, 05:30 PM
Okay, thanks for the tips. It sounds like this can be done relatively simply without the need for a high-end machine shop to get usable results. Time and elbow grease I have in spades.
Thanks to all of you for the support.
Old 07-20-2011, 05:33 PM
ger21's Avatar
If you feel creative, here's how I do mine, with minimal tools.
http://www.cnczone.com/forums/diy-cn...s_without.html
Substituting ACME with Trapezoidal ("Metric" ACME) rikun Linear and Rotary Motion 2 07-09-2009 04:39 PM
can stub acme be changed to acme osiris999 General Metalwork Discussion 4 01-28-2009 02:00 AM
Need Help!- new Machine...question about acme lead screw Ncflatlander DIY-CNC Router Table Machines 6 01-09-2009 04:49 PM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 05:47 AM
what acme tap do I need for the Enco ACME rod? AJ_Mac2001 DIY-CNC Router Table Machines 15 03-08-2004 07:24 AM
