Old 07-19-2011, 03:35 PM
mauribastidas is on a distinguished road
Problems working the end of some ball-screws
I have some problems working the end of some ball-screws from Keling, they are really hard and the lathe doesn’t “clean” the thread of the screw, I think that it would be a good idea to heat them in order to “soften” the metal, is it a good idea? How can I solve this problem, thanks for your help.
Old 07-19-2011, 07:20 PM
mactec54 is on a distinguished road
mauribastidas
Don't heat it up, if the heat travels up the screw,it will soften the screw were the ballnut runs & that would be bad
If you can't get it machined, set up a grinder to do it, or have it done in a machine shop that have a grinder
I show how to do this in a lathe, here in my machine build
http://www.cnczone.com/forums/cnc_wo..._friend-7.html
Mactec54
Old 07-19-2011, 07:47 PM
tskguy is on a distinguished road
‪screwballs pool scene .‬‏ - YouTube
Screwballs!!! thats funny
Old 07-19-2011, 08:37 PM
Gumby is on a distinguished road
Originally Posted by mauribastidas View Post
I have some problems working the end of some screwballs from Keling, they are really hard and the lathe doesn’t “clean” the thread of the screw, I think that it would be a good idea to heat them in order to “soften” the metal, is it a good idea? How can I solve this problem, thanks for your help.
Do you mean ball-screws? I don't think you should heat them up if this is what you are talking about. Depending on the particular grade of steel they are made out of that may actually make them harder when it cools.
Old 07-19-2011, 10:44 PM
Thanks for your help mactec and gumby and sorry for the mistake, they are ball-screws. I suppose it is not polite to joke about this kind of errors, especially when English is not your first language.
Old 07-20-2011, 02:02 AM
Gold Member
RomanLini is on a distinguished road
You can use a bench grinder or even an angle grinder to take off the top hardened skin of the metal, it does not need to be pretty as you fix it up with the lathe afterwards.
Old 07-20-2011, 11:36 AM
RomanLini
On most good ballscrews the hardening is deeper than the amount that you will be machining off the screw, So rough grinding does not help that much, But can help if you can grind it off even all the way around the area that you are going to machine, Carbide does not like machining a rough bumpy/uneven hard surface, & can end up worse to machine if not ground smooth & round
The ballscrews in my build that I showed being machined still had more than .060 of case hardening left when machining was finished
Mactec54
Old 07-20-2011, 10:25 PM
Thanks for you interest in my problem, I supposed it was a good idea to heat the screw but you say that it is dangerous because it can affect the hardness of it. Is it a big variation considering I would heat only a short part of the screw?
Old 07-20-2011, 11:22 PM
acondit's Avatar
acondit is on a distinguished road
Wrap a wet rag around the screw below the part you are going to aneal (soften). It will act as a heat sink and protect the rest of the screw.
Alan
http://www.alansmachineworks.com
Old 07-21-2011, 08:46 AM
Gold Member
Originally Posted by mactec54 View Post
RomanLini
Thanks for the info Mactec54, I've seen how good your machining work is so you won't get any arguments from me!
My limited experience was based on my 12mm ballscrews that only had thin surface hardening, so that ground off easily and then I lathed it down to 1/4" for the couplings.
Problem- Red dot not working Dubliner Laser Engraving & Cutting Machines 6 11-19-2010 04:48 AM
thc working or not? empirecustoms Mach Plasma / Laser 5 12-21-2008 04:15 PM
What are you working on? stevehuckss396 I.C. Engines 12 12-05-2008 03:00 PM
Trying to get my x2 CNC working... TheWolf Benchtop Machines 14 03-26-2008 09:27 PM
Something I was working on when 22 Hobbiest CNCzone Club House 1 03-13-2004 07:27 AM
