small 5 axis test
http://www.youtube.com/watch?v=XmTzc2iHKgY]small 5 axis test - YouTube
My previous 5 axis machining made into steel.
more tests big 5 axis on saturday
small 5 axis test
Simply awesome
small 5 axis in action
film from telefon haha
http://www.youtube.com/watch?v=F6jqU9sjmps]zgrubne frezowanko kopyta - YouTube
Great job man that is so Damn Cool!!!
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
another video of milling hoof
http://www.youtube.com/watch?v=DuTR5I4fRnk]zgrubna mdf HT5000 - YouTube
big.
CNC router engraving tools, carving bits
www.tayoutec.com
what are you making out of that huge stack of mdf?
Hoof trimming the thermoforming plastic
That's a nice table! I eventually want to build my own but for now im working with a EZ CNC table, I like it alot!
we did rebuilding Z axis - ballscrew, 2xpiston fi 100x2000mm's
reduced the cross-section with 500x500 to 300x300 mm's
http://www.youtube.com/watch?v=a7B-RdImbk8]Big 5 axis cnc - rebuilding Z axis test - YouTube
The effect of momentum on this must be enormous surely?
cheers,
Ian
It's a state of mind!
I wrote an ebook about this machine
The book is a lot of pictures, drawings with dimensions and descriptions.
And the whole history of the machine
cost about $ 20
here you buy
This moment is small
I wrote the ebook for some interesting observations.
I would say the heck with the machine that size, I want a space that large, then I could fill it will all kinds of 'toys'!
Hi Bartosz,
I bought Your e-book about giant 5 axis machine and have few more questions:
1. You vaguely explained most important thing for me - about leveling long ( all axis are long in this monster) axis, mounting rails... You mentioned that grinding would be impossible or astronomically costly, so what decision did You make ? Did You use self leveling epoxy or shims ? Because I cannot imagine how to weld 9 meters long structure with 0,2mm tolerance.Same question for Y and Z axis if its different technique.
2. Did You use any measuring equipment to check straightness, perpendicularity,parallelism of axis ? how to check parallelism between axis 5 meters distance apart ?
3. "therefore lower cup ring is slidable in the vertical axis in the range of 2-3mm".
Can You explaine more, or give some pictures how did You make slidable fastening to Hiwin trolley, or maybe I completely misunderstood the construction.
With all due respect to Your work, I recommend to give e-book to edit to someone who is proficient in English, because there was plenty of places I didn't understand what You mean. (Not one or two places, but 10,20 or more...) Writing in forum is OK, but then You ask money, it's a bit different.
Greeting from neighbourhood, Lithuania
Straightness of - pads with feeler
plane of - water pipe device - two tube, garden hose and water
angles - the diagonal measurement of the milling and setting the gate on the drive rack gear
the lower ring isn't connected with the cup axis, but it is tightly folded.
