Old 04-04-2011, 05:32 PM
Pplug's Avatar
Pplug is on a distinguished road
kl-600-48 power supply low voltage on switch?
I posted this in the keling forum but i think i would geta better chance for a response here.
I noticed that the kl-600-48 power supply has a remote control on the R.C.G. and R.C. terminals. What is this for? Could I remotely turn on the power supply with a low voltage switch? -That is truly what I would like to do.
Does anybody have any experience using these terminals on the power supply?
I did a quick check of this on the forums and didn't see any thing.
Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
Old 04-04-2011, 07:31 PM
Al_The_Man's Avatar
Would it be load end regulation maybe?
Many power supplies have a couple of terminals for a pair of conductors that are run parallel to the main feed pair and monitor the volt drop on long runs, the voltage is then automatically adjusted accordingly.
If not used, these are usually jumpered out to the respective supply terminals right at the power supply.
Actually I looked at the site and these are the -S +S terminals, the ones you refer to do appear to be remote turn on, although how they are used does not seem to be clear, it appears they should be jumpered to turn the supply on?
Old 04-04-2011, 09:13 PM
Pplug's Avatar
I thought the same about them being jumpered to turn the power on but they are not jumpered now and the supply has power when plugged in! One of the terminals does have +5 volts and the other appears to be a ground.
Old 04-05-2011, 01:21 PM
brtech is on a distinguished road
This is a Meanwell SP-500 series supply.
www.meanwell.com/search/sp-500/sp-500-spec.pdf
The spec sheet for the supply says it has a remote control and: RC+/RC-: Short = power on ; Open = power off
It does appear that R.C. is RC+ and R.C.G is RC-. I'd try jumpering them and see what happens. Wouldn't be the first time a datasheet from Meanwell had it backwards.
S+/S- appears to be the remote sense inputs.
Old 04-06-2011, 04:09 PM
Pplug's Avatar
Well, I did a little playing around today. I shorted out the terminals and nothing happened. The terminals are not labeled the same as the manuals I've seen so far. Here is a picture of the actual ps.
Old 04-06-2011, 04:14 PM
Huh. Sure doesn't look like the Meanwell.
I don't see any terminals listed as RC and RCG. I see sense+/-
Of course you can get remote control from Mach, a Bob output and a relay!
Old 04-06-2011, 04:30 PM
Pplug's Avatar
Yeah, that is the standby solution. I was hoping for a streamlined solution. I'll probably just wire the 120v hot wire to a switch in the front of the router and then back to the ps and be done with the whole mess.
Old 04-06-2011, 04:36 PM
Yah, that's the easy way (and my way).
I do point out that you probably DO want Mach control for the spindle, and once you start down that road, an extra relay and output isn't much work/expense/trouble other than the fact that you need a separate PS for the relay if you do remote power control, which you don't need for remote spindle control.
Now, another idea entirely is to use a push button to turn on, and a relay to turn off the power. I'd probably have both on and off push buttons. You wouldn't need a relay power supply for that. "On" would go across the relay contacts (NO). Off would go in series with the relay coil (NC).
Problem- BMC20 Low Voltage Power Supply Rally HURCO 0 08-06-2009 05:28 AM
Low(ish) voltage high amp power supply? DeusExMachina General Electronics Discussion 2 05-22-2009 09:56 PM
Lowering Power supply Voltage? tesart General Electronics Discussion 2 12-12-2008 07:43 AM
power supply voltage question Monte Stepper Motors and Drives 3 03-06-2008 10:06 PM
How do I limit voltage out of a power supply? buscht General Electronics Discussion 11 01-05-2005 08:03 AM
