Old 03-31-2011, 07:23 PM
gearsoup is on a distinguished road
Proximity or mechanical limit switches?
What are the pros and cons of each? I've seen builds use either setup. Just looking for some general info if you please
Using Mach3, what is a brief discription of the wiring sequence? Anything else needed to use limit (proximity or otherwise) switches?
Old 04-01-2011, 12:57 AM
saghirecho is on a distinguished road
u can find three wires with your switch of connector with ordindery switch simplly attahc switch body to computer pin and use + and 0- according to diagrame indicated on your switch and use out for computer pin it is preferred that you use these with opto coupler
saghirecho
Old 04-01-2011, 04:46 AM
ssutton is on a distinguished road
I personally use a mechanical switch for each axis for my limits, one for each of the three axis for a total of 6 switches. I do not use them for homes. I have my machine set up with 3 hall effect sensors for the homes. The mechanical nature of the switches could cause variability within the machine's 0 position. Many people use mechanical switches and have complete success, however, I am a controls engineer at my day job and I know that inductance type sensors that do not require physical contact will be more repeatable over time when compared to mechanical devices. It really depends on your machine and what your goals are for it. If you build it with the most expensive and precise bearing and drives components then YES go with inductive sensors for your homes. If it is mostly for wood then just use mechanical devices.
-Scott
Old 04-01-2011, 05:16 AM
Gold Member
RomanLini is on a distinguished road
There is a good thread on electronic home switches here;
http://www.cnczone.com/forums/open_s...made_easy.html
They can be used for home or limit switches, and have better accuracy and longer life than mechanical switches.
Optical vs Mechanical Limit Switches ronncat Benchtop Machines 17 01-02-2011 09:08 AM
Newbie- Home Switch (Mechanical, Photo or Proximity) mkenney Benchtop Machines 21 02-11-2009 11:35 AM
New Machine Build- limit switches -proximity sensor vs optical circlecn Benchtop Machines 1 09-11-2008 11:10 AM
PROXIMITY SWITCHES CHANDRU General Electronics Discussion 1 12-12-2007 07:33 AM
proximity switches woodguy7777 Commercial CNC Wood Routers 4 04-29-2006 04:17 PM
