Hi, My machine is just starting to breathe life but I am confused about several SIMPLE aspects of machine operation and need some assistance. Using Mach3, I have configured one of my inputs on my G540 to be the Z limit. I can connect this input to a flat piece of .032 aluminum and jog my Z down until it touches the aluminum plate on top of my workpiece. At that point I can 0 the z axis, but it is not really 0 because it is .032 above the work surface. What do you do to correct this? Thanks for the help, without this forum I would not have a machine at all. Scott |
| Go to the main page on Mach 3. Then there is a page lableled "Offsets" open that screen and look under "Gage Block Height". Place the thickness of your touch plate in that dialog box, press enter, then as a precaution I always choose save settings under the "config" drop down at the top of the screen. It has an option "save settings". Hope it helps. |
| You can also go into the MDI box and enter G1 Z-.032 F1. This will make the Z go down the .032 at a feedrate of 1 unit per minute. Once the tool has arrived, reset Z zero. Though the tool setter/gage block is the way to go. |
| Ideally, you should have the plate wired to the probe input, and use an auto zero probing routine. See the Aussie tool setter thread in the project log section. It's a sticky at the top.
| Understanding encoders. | Konstantin | Servo Motors and Drives | 4 | 11-05-2008 09:47 AM |
| using and understanding mach3 | D CUSTOMS | Bridgeport and Hardinge Mills | 1 | 06-12-2008 09:13 PM |
| Understanding Plasma THC | nerginer | CNC Plasma and Waterjet Machines | 10 | 09-12-2007 04:33 PM |
| General understanding of more than 3 axis help please! | Dongle | General CNC (Mill and Lathe) Control Software (NC) | 9 | 02-22-2006 08:45 AM |
| Need help with driver understanding | ArtistEd | General Electronics Discussion | 2 | 02-07-2005 09:34 AM |
