Greetings all, I have a small table top cnc router (12x18) it supposed to have 14-4 lead screws, they are from the orient and are trapezoidal. I can't seem to find any nuts to replace the crappy plastic nuts that the builder used. very sloppy nearly 1mm. I would hate to replace the screws if I can get the proper nuts and clean up this slop. I don't know what kind of tolerances I can attain with these screws. I am new to this type of machining. I was looking into ballscrews but not sure it's worth the money. I originally hoped to do some jewelry work with this. would love suggestions and suppliers! thanks |
I will be happy to change the screws and nuts b ut I don't know exactly what to change to that will be comparable to the 14x4mm lead that it has. I looked into 5/8 x 8 acme but don't know enough about it. then I don't know if I have to retune everything, as I said I am a newbie to cnc. I have a very old Austrian Maximat combo in the garage and that I know how to use. |
| You could go with 1/2-10 2 start acme screws. Those would be pretty close, and if you want to do really fine work those could be a good choice. They would give you more resolution and lower speed than what's typically used for routers here - more like 1/2-10 5 start.
__________________ CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html |
| I'd also recommend the dumpstercnc nuts. They've held up well pushing around my 140lb+ gantry.
| Finding the right nuts is not the only problem .. in metric sysem there are several norms ( DIN ISO and the Japanese Norms ).. regarding the accuracy and reliability components of both systems should not be paired... 14x4 is very uncommon - 14x3 seems to be use sure that you would not be wrong with 14x4mm http://de.misumi-ec.com/pdf/fa/p1_0719.pdf Here you can order the 14x4 nuts for about 10.1 Euro p pcs Runde Muttern mit Trapezgewinde, eingängig rechts, Rotguss - Mädler Webshop DATASHEET ( unfortunately in German ) http://www.maedler.de/Article/64331400.aspx
__________________ Why reach for speed, when you could have precision instead!!! Last edited by Harpye; 04-02-2011 at 05:10 AM. |
| Tags |
| lead screws, leadscrew nut |
| Please help find 3/8 face sealing nuts | Tig Artist | General Metalwork Discussion | 1 | 01-10-2009 02:32 AM |
| Need M18 x 4 Trapezoidal Nut | DareBee | Want To Buy...Need help! | 1 | 01-29-2008 11:42 PM |
| 3/4-6 Nuts? Where to find? | Joe Petro | Linear and Rotary Motion | 2 | 03-25-2006 01:26 AM |
| Can't find nuts! | Xterrian | DIY-CNC Router Table Machines | 3 | 08-07-2005 01:14 AM |
| trapezoidal screws? | sixpence | DIY-CNC Router Table Machines | 4 | 01-26-2004 06:23 PM |
