  #13
Old 08-22-2005, 09:50 AM
ger21's Avatar
Originally Posted by miljnor
screw lead is the threads per inch 13/64"(for the 5/8" ball screw/nut) lead is very close to 5 threads per inch.
I was under the impression that McMaster Carr rounded off to the nearest 1/64", and the actual lead is 5 tpi.
Old 08-22-2005, 10:46 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
well if they rounded off I think the documentation would read differently, but I have bought the roton stuff and a freind bought the MCmaster stuff and side by side they are definitely different. So I would not assum its 5TPI, but it is very close. Not to mention the roton screw is thru hardend and ground and the Mcmaster is rolled and case hardend.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 08-22-2005, 10:58 AM
ger21's Avatar
OK, then. It just seemed that everyone that talks about them always calls them 5tpi. Thanks for the clarification.
Old 08-22-2005, 11:03 AM
miljnor's Avatar
S.N.A.F.U.
it is realy close And I too refere to them as 5tpi but its .2031 lead vs a 5tpi .2000 lead. So on a number bases i would say they are close to equal but personaly wouldnt mix them.
thanks
Michael T.
