Old 03-29-2011, 06:23 PM
JTCdudeman is on a distinguished road
Cutting Aluminum Learning Curve
Hey guys. I figured I would post up some pictures and info on an experience I had using my CNC router. First off, its a FLA 200 model paired with a Hitachi M12vc router.
Today I was cutting aluminum very succesfully for the first time after a ton of trial and error. I spent days researching on how to cut aluminum best and go nowhere fast. I literally had 12+ hours reading forum posts and sadly got better information on cutting aluminum in 10 seconds from Ron Reed at Precise Bits when I called to ask about an issue I encountered. Ive cut over 40 items in aluminum just trying to find the right settings to use and the best results I have had included one major thing.
Cut depth. Cut multiple passes at a very shallow cut depth for a much cleaner and more effective cut. Chip clearance works much better and alot less heat is generated. I was cutting at .007" per pass. As mentioned above, Ron suggested a .010" cut depth or less. So, thats my advice for anyone looking to cut aluminum without flood coolant on a woodworking machine.
Anyways. On to the pics and learning curve.
What I learned: Always tighten your collet as tight as you can! Snug isnt good enough.
Why I learned this: My bit spun in the collet when My aluminum bowed up and I ended up cutting .125" in a single pass and breaking the bit. When the bit spun in the collet, it fractured and pieces of the carbide bit embedded into the collet.
Pics for anyone who'd like to see it.
Aluminum cutting info:
Bit: 1/4" Carbide High helix AL 2 Flute
Alloy cut: 3003 aluminum 1/8" sheet
Spindle Speed:24,000
Feedrate: 84 IPM
Depth of cut: .007"
BTW: I was able to reposition my hold downs and cut the part fully with great success once cutting was at a uniform depth through the entire toolpath.
Old 03-29-2011, 07:46 PM
nulluser is on a distinguished road
What spindle speed do you estimate you were running at? I'm having a lot of problems with it gumming up. I can cut it with no problems on my mini mill, with the same tooling.
Old 03-29-2011, 07:56 PM
towertek's Avatar
towertek is on a distinguished road
For cutting aluminum plate with a 3hp Millwaukee Router @ 10,000 rpm,
I use a single flute 1/4" solid carbide end mill.
I run about 22ipm with a pass depth of 1/8".
And i use a spray coolant that is 8 parts water and 2 parts dish soap.
The results are outstanding!
Old 03-29-2011, 07:59 PM
towertek's Avatar
Gumming up or Galling
Make sure when you are routing aluminum , that you are throwing of the biggest chip you can handle. These carry the dreaded heat away and ensure the best quality cut.
Old 03-29-2011, 08:05 PM
Spindle speed: 24000 rpms. Yes, max on my router. Probably running 20k under load.
Feed: 84 IPM
Cuts like butter so long as the pass depth is .010 or less. Anything any deeper and it gums up hard.
Warning: VERY Small chips!
My break wasnt associated with the feeds and speeds best I could tell. It was a cut depth at those feeds and speeds issue. With all of the cutting I was doing, eventually my piece bowed up in the middle because my hold downs probably were not adequate enough. I guess heating up aluminum by cutting on it for more than an hour straight makes carpet tape lose its grip.
Old 03-29-2011, 08:17 PM
louieatienza is on a distinguished road
My belt/pulley/leadscrew system on my x axis somehat limits my feedrates with aluminum, but after some testing, I was able to achieve 100ipm at .075doc with a 1/4" bit. This is maxing things out; I would typically run at 40-50ipm with a 1/4" bit at .035doc. With a 1/8" bit I'm at about 30ipm and same doc. I only use an ocasional spray of WD-40.
The other thing is spindle speed. You need to lower the spindle speed enough to produce chips, not aluminum powder. The problem is your router may not have enough torque at that speed and the machine may not be ridgid enough to handle this at higer feedrates. I have a SuperPID on its way which should help in that regard (Roman!)
I've been using spiral-o-flute bits from Amana with success. Having only 1 flute really helps with producing chips, since I can keep the rpm relatively high. Note Amana recommends 120ipm at 18krpm with a 1/4" bit and 1/4"doc! I have also purchased 1/16", 1/8", and 1/4" super-o bits from Onsrud (through Enco) which seem to be of better quality, though untested due to router mods I'm making now (new ab motor couplings, SuperPID installation prep, etc)
Another thing is the type of aluminum you're using. I've been using surplus Mic-6 aluminum tooling plate bought on eBay. The difference is it's cast, which makes it easier to produce chips without galling. I haven't tried it yet, but I think 7050, 7075, and 2024 should work as well...
I've cut quite a few things witn aluminum, some of which is in my YouTube page YouTube - AtienzaLouie's Channel. Heck, I was even successful with my wooden Solsylva machine! The descriptions have more info on the cutting parameters I used. Hope it helps...
Old 03-30-2011, 08:38 AM
michaelthomas is on a distinguished road
I have some 3/16 Onsrud single O-flutes that I have run at 20,000 rpm and 60ipm at 1/2 cutter width for depth of cut (.09375). I was just giving it a shot of WD-40 every 5 second or so, and using an air nozzle to keep the chips from building up in the groove. Haven't broken one, yet......and the cut quality is pretty nice. This was on 1/2" 6061. Doesn't use much spindle power.....it hardly seems to notice its cutting at all.
The single flutes don't seem to leave the best bottom finish, though.
Old 03-30-2011, 03:13 PM
Pplug's Avatar
Pplug is on a distinguished road
I use a Chinese 2.2kw spindle at 7680rpm with a 3 flute aluminum cutting bit at a max depth of .05" at a speed of 30 imp. I use a little wd-40 and compressed air to cool and blow out swarf. It leaves a mirror finish! I'll post som Picts when I get a chance.
Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
Old 03-30-2011, 06:04 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Guys, you want to try for a chipload in the 0.002" per tooth range. You can look up the formulas for that, or get G-Wizard on trial to figure it out.
If you just plug in 24K rpm, the feedrates to generate 0.002" chipload are:
- 2 flute: 96 IPM
- 1 flute: 48 IPM
It's proportional, so at 12K rpm you need half the IPM travel rate. You can see how single flute cutters have more manageable feedrates, as was suggested. They will also clear the chips better.
Don't slow down too much or you'll burn the cutter. I wouldn't let the chipload fall below 0.001" if your cutter is 1/8" or larger. What happens is you start burnishing the material and it "rubs" instead of cutting. Much heat generated!
Also, the small chips are not necessarily easy to clear, especially if you're using WD-40, which will kind of ball them up into a sticky mass.
Depth of cut in a slot will limit your ability to clear chips. Too much width of cut is also hard on the cutter. When cutting full width, you only give each flute 1/2 a revolution to cool off and get rid of any chips it picked up. Try to use 25-40% stepovers and things will be happier.
When you are thinking about your toolpath, try to arrange it to leave room for chips to leave. Beware tight corners and such. Open out a cavity where they can't hide early, and blow air at it to keep them out of there.
You can do nearly as well as flood coolant if you're diligent about the lube mist and keeping the chips out of the cutter. Just to emphasize that last, I see more peeps breaking tools in aluminum because they had no lubrication or because they didn't clear the chips enough than from bad feeds and speeds.
You want to be totally paranoid about recutting chips. Get them out of there with compressed air or whatever. If you have to stand over it with the air hose, dem's da breaks with aluminum. It also needs lube or it tends to weld onto the tool. WD-40 works great. If you can run a coolant mister, you get both the lube and the chip clearing in one shot. If not, at least running an air jet that travels with your router will mean you have to watch it yet.
That MIC6 looks cool, but it is way gummier than most any of the wrought aluminums like 6061 or 7076. They all cut easier and better than MIC6.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 03-31-2011, 05:23 AM
iplay1515 is on a distinguished road
What Bob said with emphasis on 6061, single flute, < 40% stepover, and chip removal. I use Tap Magic Aluminum for lube.
Keep in mind that most routers have large swings in motor speeds from different loads. It's the actual speed of the cutter under load that you want to use in your calculations. Unless your router has a closed loop speed controller, no load speeds can be very misleading.
In most cases, metal machining requires both rough cuts and finish cuts. Often, a tool change is necessary for optimum results and finish.
  #11   Ban this user!
Old 03-31-2011, 06:55 AM
Usually for profiling, I stick with the spiral-o, it gives a pretty good finish. If the finish is not critical on the pocket floor, I keep it as-is with the spiral-o. If I want a smoother finish or it's a visible part, I'll switch to a 2-fllute bit.
As my system has a little bit of flex, if I need a more accurate cut, I'll do the finish pass with conventional milling. Also I'll switch to a smaller diameter bit for outside profiling if I need more detail in the profile.
I use the rest machining feature in VCarve Pro if I need more detail in the inside profile, bosses, etc.
The mic-6 IS 6061, just cast and milled flat. I'm not really equipped to do facing operations and the pre-milled surfaces really helps a lot and looks good! Not prone to warp when machined. Plus you can get it very inexpensively if you hunt around, even cheaper than regular 6061 sheet!
  #12   Ban this user!
Old 03-31-2011, 08:50 AM
Alcoa lists Mic 6 as a 7000 series alloy. My experience with it is that it's pretty gummy compared to 6061.
MC learning curve? Ted Filley Mastercam 2 03-09-2011 07:42 AM
Newbie- Cutting along a curve. Odd Egeland MadCAM 8 04-02-2010 06:29 AM
Learning curve! IanH Benchtop Machines 1 06-01-2009 08:36 AM
What's the learning curve for the TL-2 rbest27 Haas Mills 4 12-18-2006 10:29 AM
First of many questions in learning curve STS_John Daewoo/Doosan 11 09-19-2006 05:29 PM
