| Greetings. I have been lurking here for a while and have finally amassed enough knowledge to attempt a router build. 3D Model: Y table: ![]() Chassis: ![]() Chassis with X and Y: ![]() Y Motor Mount: ![]() Full unit, without motors: ![]() Routing Test: ![]() ![]() Pocketing: ![]() Video: YouTube - CNC Router Ripping It Up. Full 3 AxisParts: Motor Driver: Gecko G540: 250 Motors: 3x Vexta PK266 166 oz-in: 75 Linear rails: 250 ACME Leadscrews 1/2x10 single start: 70 ACME Nuts (Plastic): 30 Flex couplings: 30 MDF: 60 Aluminum: 60 Hardware: 100 PC: 200 Mach3: 150 Power supply 24V 10A: 30 Bosch Colt Router: 100 Bearing blocks: 85 Total Cost: ~1500 The unit can do 100 IPM rapids. I'm not happy with the rigidity of the X and Z rails, the next one will use fully supported rails. The G540 is an excellent drive. I have burned up a few of the cheap Chinese drives before biting the bullet and getting the real thing. I'm using Algolab R2V to convert bitmap files to DXF, and using master cam to generate the G-Code. One question. What is the proper technique for routing out plexiglass? I'm cutting at 50 IPM with the router at the lowest speed, and it still melts. |
| Tags |
| diy cnc router g540 |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-07-2011 11:16 PM |
| Build Thread- Building a CNC Router; by someone who can't build a CNC Router | Womble | DIY-CNC Router Table Machines | 2 | 09-27-2008 07:51 AM |
| Router Using 3/4" MDF (first router build) | eguy208 | CNC Wood Router Project Log | 33 | 04-11-2008 10:33 AM |
| Build a CNC Router - FAQ | samualt | DIY-CNC Router Table Machines | 7 | 04-13-2004 08:55 AM |
