Old 03-27-2011, 01:41 PM
Harpye is on a distinguished road
Mobile Mill To Go
1 week ago I started to setup a new project :
Target spec ist to create a fully capable 3D router with maximum working area possible in respect to the following restrictions:
Weight - below 30 KG - Airfreight compatible!
Same cutting power as my big machine with appr. 200 KG
Capable to cut aluminium plastics and other prototyping materials
Fast assembly and disassembly like a killer gun
Dimensions in disassembled state to fit in a pilot case or similar transportation and protection casing
And so I went on ...
Machine frame is made from fine planned aluminium
equiped with modified professional linear tec
motors will be stepper motors and Spindle will be a 700W to 1KW high speed AC spindle
ID:	130030   Click image for larger version
ID:	130031   Click image for larger version
ID:	130032   Click image for larger version
ID:	130034   Click image for larger version
Why reach for speed, when you could have precision instead!!!
Old 03-27-2011, 02:06 PM
TarHeelTom is on a distinguished road
This looks like a fun project !
Tom
Old 03-27-2011, 02:14 PM
Hope it will be ! Thanks!!
Old 03-27-2011, 03:31 PM
xclr82xtc is on a distinguished road
sooo...how bout that business model?? lol.. jk.
Old 03-27-2011, 03:44 PM
Nope .. Its just a coarse idea but before talking about it I will have to prove it ... ( until that point is established I just invest in the long term activities and low material costs... the plained aluminum for the frame is about 200 the additional effort lateron is 2.5 thousand... so I keep that secret at the moment..
the BC that was one of the first questions in the German forum without placing the first remark ...( but I should have learned .... reversible psychology works )
Old 03-29-2011, 01:42 PM
Now I got a bit further - Nut and bearing blocks are cut and lightened
and today I decided to get into the fixation elements for the loose side block
including the "O" for the inductive reference switches...
Old 03-29-2011, 05:15 PM
Zygoat's Avatar
Zygoat is on a distinguished road
Cool machine.
Old 03-30-2011, 03:19 PM
Hope it will be ... Did the endplates for the x Axis today ... now its ready for the linear tech ... but the others are still missing!!!
Old 03-30-2011, 04:43 PM
zool is on a distinguished road
Brilliant idea; exquisite engineering; stunning execution.
Old 03-30-2011, 05:08 PM
cheetahcnc's Avatar
cheetahcnc is on a distinguished road
I like the lightening technique and workmanship quality on your plates. When finished, these machines will be functioning, crafted works of art. Real nice work
  #11   Ban this user!
Old 03-31-2011, 09:55 AM
Thank you guys for that comments - I really try to get this single piece done to a certain level of satisfaction for me .... I 'll do this one once and try to get it done as good as I can!!!
  #12   Ban this user!
Old 03-31-2011, 02:09 PM
Here is a little bit of finishing work ( fine plain Alumium is not available in thicknesses below 10mm so I tried to give my 5mm normal plate a shiny look
In Swizerland they would call it " Genfer Streifenschliff"
Need Help!- Spindle information for Various Milling Purposes joprinz General Metal Working Machines 3 09-19-2008 05:16 PM
Newbie- Spindle information for Various Milling Purposes joprinz DIY-CNC Router Table Machines 0 09-01-2008 08:30 AM
Mobile base for IH Mill ProGunOne Industrial Hobbies (Support forum) 6 01-16-2008 04:03 PM
Commercial CNC mill - BZT and Heigh Z Kent_Norway Commercial CNC Wood Routers 0 10-01-2007 08:50 AM
Partime Position for Jobout Purposes frickles Employment Opportunity 0 09-30-2007 06:33 AM
