Old 03-26-2011, 04:05 PM
DonFrambach is on a distinguished road
Problems with Wolfgang spindle
I'm using a Wolfgang spindle driven by a 12v motor to make detailed carvings in wood using my 14"x14" router.
It was working great but the last two projects were ruined because the bit slipped in the spindle. The bit slipped down in the spindle thus gouging the workpiece and then the bit broke.
I was using 1/8" fishtail bits obtained from PreciseBits.com to cut hard maple at .05" DOC, 30"/minute, and about 20k rpm.
Anyone have this problem? Any ideas why the bits are slipping? Better yet, any solutions? I'm going to use my Taig spindle for now.
TIA
Don
Old 03-26-2011, 04:17 PM
robe_uk's Avatar
robe_uk is on a distinguished road
Ensure the collet is absolutely free from any specs of dust or dirt, also check up in where the collect sits in the spindle, I've seen specs of dust mentioned before causing problems.
good luck
I'll get it finished sometime after I start it.....
Old 03-26-2011, 05:24 PM
Drools's Avatar
Drools is on a distinguished road
I sent you a PM Don.
Wolfgang Spindle Options Drools PCB milling 21 09-26-2010 04:47 PM
Wolfgang Spindle dpaish DIY-CNC Router Table Machines 3 09-19-2010 12:14 AM
Wolfgang spindle hmm mholod General Metalwork Discussion 12 06-02-2010 02:18 PM
Wolfgang engineering spindle frejohg Want To Buy...Need help! 5 11-14-2008 04:13 PM
WolfGang Eng Spindle wcarrothers1 DIY-CNC Router Table Machines 13 02-14-2008 09:54 PM
