Old 03-26-2011, 03:09 PM
LabSkis is on a distinguished road
About Z axis (using CncrouterParts carriages)
Hello,
I am designing a 8020 aluminium frame CNC.
I will post someday pictures of the full machine I intend to do.
It is partly based on what Arbo has made, but adapted to european standards/shops.
For the moment, I have troubles with my Z axis design that you can see in pic 1.
For those who know, I have used carriages from Ahren Cncrouterparts.
My concern: how to get the maximum travel on z axis.
Lets have a closer to my design on pic 2
On this picture, I have put the z axis as low as possible.
For me, the available travel is min 30 mm (cf. picture), depending on the length of the bit I will use.
How can I increase this travel?
Fix my router further down on the interface plate? I fear cantilever...
For the moment the router is fixed 30 mm below the carriage (see pic3)
Can I increase it?
Other solutions you have used?
Like the one proposed by Ahren on his site, consisiting in fixing the carriages on Y axis & letting the 8020 of the Z axis move up & down? Any feedbacks on this?
ID:	129918   Click image for larger version
ID:	129919   Click image for larger version
Old 03-26-2011, 03:17 PM
DonFrambach is on a distinguished road
I think that the CNCRouterParts.com Z axis works much better when the carriages are mounted back to back instead of on the Z plate that you have in your current design. I originally made my Z axis that way and had the same concerns that you have about travel and placing the cutter too far from the bottom bearing.
CNCRouterParts.com also sells what they call their "high Z plate" that allows for what I believe is a much better back to back mounting of the carriages. I made my own plate because I wanted to incorporate a spacer needed for my design. Here's a link for their plate: CNCRouterParts and a photo:
Old 03-26-2011, 03:24 PM
Yeah, that was what I meant with my sentence "in fixing the carriages on Y axis & letting the 8020 of the Z axis move up & down?".
I won't be able to use that plate either, because it won't fit with my european design!
Are you happy with it? What "travel" did you get?
Old 03-26-2011, 03:27 PM
What I made is listed in post #20 and #24 (and others following) in this thread: http://www.cnczone.com/forums/diy-cn..._router-2.html
So far I'm real happy with the design. I made mine to have 5" of travel but that length is arbitrary because I could have used a longer or shorter piece of steel to increase or decrease my Z axis travel.
Don
Old 03-27-2011, 04:23 AM
OK, I have just redesigned it according to your idea.
Now I have about 70mm for z axis, but i can change it!
Unfortunately, I have had to add many interface plates (like in pic 3, corresponding to Z axis rail & carriage) to allow me to use dumpstercnc nuts. They are are about 30mm high, whereas the distance between the top of the carriage and the metal rail is something like 25mm (see pic 4). I fear cantilever again!
Any advice to avoid that?
ID:	129996   Click image for larger version
ID:	129997   Click image for larger version
ID:	129998   Click image for larger version
Old 03-27-2011, 06:55 AM
ger21's Avatar
What about mounting the screw on the side, rather than behind the plate?
Old 03-28-2011, 02:16 PM
johngalt47 is on a distinguished road
y/z axis with back to back bearing trucks
The design I am working on the z axis uses the carrages back to back design
the area in the box shows details of the z axis. Notice that the motor moves with the router it adds a little weight but I have added two gas springs to couterbalance the weight. this is not a finished drawing but it shows the details that you are dealing with
Old 03-28-2011, 02:47 PM
let try this again i hope it is clearer
Tags
8020, design, z axis
Need Help!- Protecting CNCRouterParts Carriages Drools DIY-CNC Router Table Machines 9 03-22-2011 06:11 AM
Need Help!- cncrouterparts.com carriages on MDF Drools Joes CNC Model 2006 2 09-27-2010 04:05 PM
Idea for CNCRouterParts covered Y axis ben_jackson DIY-CNC Router Table Machines 6 03-19-2010 04:07 PM
Just IN- CNCRouterParts 3 and 4 axis motor kits ahren Product Announcements & Manufacturer News 0 02-07-2010 05:18 PM
THK rsr 15 rails and carriages endgrainguy Linear and Rotary Motion 5 03-24-2008 09:47 AM
