Old 03-24-2011, 09:35 PM
deonsmt is on a distinguished road
8020 CNC Router
The goal was to build a CNC router from 8020 aluminum extrusions. Ultimately the picture below shows where I ended up....
This router was built 2 years ago. I've started transcribing my notes into a blog which is part Instructable, part ramblings of someone who spent too much time in the garage.
DLS Projects: Part 1 - CNC Custom Router Intro
Old 03-26-2011, 12:19 PM
The base consists of 4 x 1030 8020 extrusions arranged to form a fully supported base. This design will have 2 lead screws on the X axis, one on either side. A slightly more expensive way to do this but it helps overall rigidity.
I've added more detail to linear motion slection and the base assembly to the blog
DLS Projects: Part 4 - Linear Motion
DLS Projects: Part 5 - Router Base Assembly
Old 04-03-2011, 02:29 PM
Added detailed dimensional drawings for the bearing blocks, motor mounts, delrin nuts to the blog. The drawings don't meet any mechanical drawing standards but have enough detail for you to make your own parts.
DLS Projects: Part 6 - X Axis
The blog provides additional technical detail of the X-Axis parts and assembly.
Let me know what you think.
Old 04-03-2011, 03:33 PM
mmcp42's Avatar
mmcp42 is on a distinguished road
always fascinating reading someone else's build log
(you might want to shuffle the order of the links on the right hand side top of your blog
seems to go 1, 2, 4, 3, 5, 6)
Old 04-03-2011, 04:31 PM
Here's a practical application of the router. A switch mount for a custom pro street chopper I'm building
Midnight Customs: Part 8 - Regulator and CNC Switch Mount
Old 04-03-2011, 05:52 PM
cheetahcnc's Avatar
cheetahcnc is on a distinguished road
Nice build
8020 Router 8' x 2' Rex 2.0 RedskinsJBS CNC Wood Router Project Log 152 08-29-2011 02:19 PM
Ahren's 8020 Router ahren CNC Wood Router Project Log 30 09-23-2007 10:10 PM
8020 BBR Router Build ddbuster DIY-CNC Router Table Machines 3 07-09-2007 07:39 PM
8020 cnc router table top eloid CNC Wood Router Project Log 0 02-24-2007 07:32 PM
Results from using 8020 for a CNC router WarrenW 80/20, TSLOTS and other Aluminum Framing Systems 0 01-05-2006 08:17 PM
