Still waiting for my machine. But while I was reading the posts in this forum, one question came up, after roughing, what is the best way to make sure the finer bit I put on will match the center point of the roughing bit? |
| Will your machine be running Mach 3? If so, you can get the Mach 2010 Screenset which will let you easily recalibrate the Z axis after a tool change YouTube - Mach3 2010 Auto-ZeroNot only is this a beautiful screenset, you can't beat the $20 price: Mach3 2010 Screenset LINK
__________________ http://paul-flores.com/ |
| The center point will always line up! If the diameter of the finishing bit is different, an offset or cutter compensation will need to be made. And of course, the end of the cutter needs to be zeroed, as previously mentioned. -Jim Hart
__________________ My main machine: Multicam MG series (MG101) with original Extratech H971 controller, Minarik servo motors, Electro-Craft BRU-series drives, 4KW Colombo. Let's talk Multicam! |
| With the post titled "About Z accuracy when changing bits", I was under the impression you were asking about Z height after changing bits. Is your question about making sure the Z height is correct, or is your question about making sure your X & Y axis remain the same?
| Design accuracy to mechanical accuracy | kbayram | Linear and Rotary Motion | 0 | 08-18-2010 03:34 AM |
| Changing router bits w/o banging knuckes? | zeeway | DIY-CNC Router Table Machines | 5 | 05-30-2010 01:01 PM |
| Router bits, End mills v bits | bogger44 | Commercial CNC Wood Routers | 3 | 12-03-2008 12:06 PM |
| Changing bits in Mach 3 | Revtech | Mach Mill | 0 | 10-19-2006 06:13 PM |
| Accuracy determination & accuracy improvement | rweatherly | DIY-CNC Router Table Machines | 5 | 08-11-2005 08:37 AM |
