Old 03-23-2011, 08:06 PM
bonmotwang's Avatar
bonmotwang is on a distinguished road
Where to buy plastic material
Receiving my desktop cnc in two weeks. Need to get some plastic material to start testing. Any suggestions for getting plastic blocks?
Of course I will use foam first.
Old 03-23-2011, 08:31 PM
bobsch's Avatar
bobsch is on a distinguished road
You didn't specify what kind of plastic, but here's a supplier that's been mentioned around here several times-- Your Source For Plastic Sheet, Slab, Rod and Tube. 866-832-9315
Bob
"Bad decisions make good stories."
Old 03-23-2011, 08:41 PM
bonmotwang's Avatar
Thanks. Truly green in CNC, planning parts for robotics. Maybe ABS. Need to do homework on materials.
Old 03-23-2011, 08:54 PM
bonmotwang's Avatar
Just looked at the price, wow. it is nothing for prototyping.
Old 03-23-2011, 09:04 PM
RicknBeachcrest is on a distinguished road
Check these guys out.
I've bought aluminum from them. Real fast shipment. They also sell plastic.
Online Metal Store | Small Quantity Metal Orders | Metal Cutting, Sales & Shipping | Buy Steel, Aluminum, Copper, Brass, Stainless | Metal Product Guides at OnlineMetals.com
Old 03-23-2011, 11:01 PM
DonFrambach is on a distinguished road
Have you considered machinable wax? Here's a supplier: Machinable Wax
Old 03-24-2011, 10:24 AM
sirkossorg is on a distinguished road
If you don't need big, full sheets, some plastics suppliers will sell you their scrap by the pound. That's how I get mine, and it's so cheap that I've been able to experiment with different types, colors, and thicknesses of acrylics that I never would have otherwise. I usually use 15" to 24" pieces. If that's big enough, you might call your local places to see.
Old 03-24-2011, 10:53 AM
atwooddon is on a distinguished road
I recently tried using Trex (recycled material used for decks/patios) and it machines great. It is very expensive to purchase but if you can find scraps from a contractor or buddy building a deck it works great.
Don
Old 03-24-2011, 11:29 AM
bonmotwang's Avatar
Thanks, that's a better solution for my prototyping purposes.
Old 03-24-2011, 11:42 AM
bonmotwang's Avatar
Great and thanks, I got 10 blocks ordered.
  #11   Ban this user!
Old 04-08-2011, 06:26 PM
LaughingLarry is on a distinguished road
Here is one I have used
Great source for cut pieces at: High-Tech Plastics
They have weird remnants of lots of different plastics in little pieces. Did it all online, took about 3 - 4 days to get. Great email communication, but no phone.
  #12   Ban this user!
Old 04-10-2011, 03:01 PM
Harpye is on a distinguished road
Tech polymeres are not that cheap as you would possibly assume..
About the prices ...
from cheaper to more expensive
-> choose by application....
Styrene resine plates / hobby glass
-sharp mill and a bit of coolant low pass depth
Polyurethane modelling board ( Uriol ; Rakutool etc)
- is to be cut like balsa - but creates a lot of dust
Polycarbonate & PVC
-Good to work with at moderate passes and speeds
Polyacetal / POM -
-Good to work with at moderate passes and speeds not to be glued
PBT - good to cut but if reinforced the glass will eat the bit a bit
- has to be tempered before
Polyamide - good to cut but if reinforced the glass will eat the bit a bit
PTFE - smooth material - not easy to work with - dust can be poisenous if inhalated or consumed
PEK / PEEK - poly ether ketone - horrible expensive but high temperature reistant
For visual and handling prototypes not field parts I would go for 700 to 800 gram/ DM^3 Uriol or Rakutool -price is around 4 to 5 Euro / dm^3
There are many more, but those are just the materials I use
Why reach for speed, when you could have precision instead!!!
Plastic Material rwskinner Engraving Machines 1 01-04-2011 09:15 PM
what material for molding clear plastic? mc-motorsports Moldmaking 22 06-29-2009 09:54 AM
Plastic Material Suppliers vetteboy86 Engraving Machines 5 10-06-2008 08:15 AM
Plastic material in VMC windows?? CNC Viking General Metal Working Machines 21 08-28-2008 04:15 PM
Plastic as the mold material gcn2339 Vacuum forming, Thermoforming Etc 3 07-30-2007 03:31 PM
