Old 03-23-2011, 07:48 AM
billturnbull is on a distinguished road
Blocked cooling lines...
Hey all,
I have a bit of a serious problem...
I have a water cooled spindle that seems to be blocked somewhere, up until now it has let enough water through to cool the spindle but now it seems to not be allowing enough water through...
Has anyone some good tips on flushing the lines?
I thought about just reversing the flow but not sure if this will cause any issues... Actually I think we tried this a while back...
Im not sure on the make of the spindle but it is an 800W head...
Thanks,
Bill
Old 03-23-2011, 05:22 PM
OK...
I hardened up and pulled the spindle off, the old man blew in it one way and didnt seem to get anywhere, then blew the other way and water came out... Now either way you blow it; it works fine and easily...
Now to go check the hoses and run some fresh water on short lines through the spindle...
Old 03-23-2011, 08:07 PM
Pplug's Avatar
Pplug is on a distinguished road
I use an air compressor to flush my coolant lines. I use a low 10-20 psi.
Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
Old 03-27-2011, 03:45 PM
compfranon is on a distinguished road
I also use a compressor to blow my coolant lines clear, strange though that sometimes I notice the flow getting slower so I give the lines a good shake and rattle, the flow returns !!! must be a bit of debris in there somewhere.
Dashed Lines?? Sames lines to still show dashed in different scaled viewports? coykiesaol General CAD Discussion 1 12-29-2010 09:38 AM
Need Help hooking up Viper200 Stop-Out lines to CNC4PC C1 BOB Input Lines CNC-Joe Viper Servo drives 1 08-11-2010 07:59 AM
access in to network set up blocked Bogdan_Celtic HURCO 8 09-02-2009 09:43 AM
stepper blocked Guy69 Hobby Discussion 3 01-16-2007 08:16 AM
Air Cooling? senor J. General Metal Working Machines 2 03-14-2005 08:05 PM
