| you cant overkill it, professional cnc use 5-20HP spindles, the more HP the faster you can move the bit through the material, as long as your machine can handle it. For my machine I use the Porter Cable 890 router, its 2.25HP and has a variable speed controller. I wouldnt go any less HP for what I do with my machine. Mostly wood and plywood. Make sure whatever router you go with, that you can mount it to your machine conveniently and easily. The porter cable line, hitachi line and some other have a nice mount made by K2 CNC which makes mounting easy. |
| I'll put in my vote for a Chinese spindle. Durable, accurate, super quiet, long duty cycle, and really powerful! They are about twice the price of a router but totaly worthit I've also owned a hitachi 12vc and it's ok as well but no comparison to the spindle.
__________________ Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3 |
| After you have figured out your specific needs, I suspect that you will covet and then purchase a more expensive spindle! |
| 1050 Watt approx 1.4hp Not much torque in the kress but fine for wood and using smaller cutting tools. Not sure about the Chinese stuff, first thought would be to avoid Chinese made products; however have had very acceptable Taiwan made products in the past, just not Chinese. Regards. |
| Don't knock it before you've tried it! My spindle from ebayer linearmotionbearings has been great. Most of the problems people have been having are with the vfd and not the spindle. I have a 2.2kw water cooled model. With a Bedford vfd but I suggest a hitatchi x200 vfd. If you buy that cheap I guarantee it will need replacing. However, the Chinese spindle option will set you back a good $600.
#10
| Hi, not trying to knock anything specifically, just have had bad experience for the most part with Chinese gear (accuracy wise). Giving something a try is fine, but if you can get Japanese, S. Korean, German, Taiwan for not much more I would go with that, its just an opinion based on experience. Regards. |
| Newbie- Buying a new 48x48 Art-Router 4 Axis CNC Router | Stoch | Open Source CNC Machine Designs | 1 | 12-17-2010 06:08 AM |
| Need Help!- with a Precix Table Router with Perske router | SignShop Grunt | General CNC (Mill and Lathe) Control Software (NC) | 7 | 09-08-2010 04:08 PM |
| Build Thread- Building a CNC Router; by someone who can't build a CNC Router | Womble | DIY-CNC Router Table Machines | 2 | 09-27-2008 07:51 AM |
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 03:33 PM |
| Surfcam PP for Isel router / Precix router | IvanTochev | Post Processor Files | 2 | 05-12-2004 12:27 PM |
