Old 03-22-2011, 04:35 AM
jeffrey001 is on a distinguished road
Joining gantry under table
Is it so important to join both side of the gantry under the table.
I have a 72 inches router table made of aluminum.
Both sides of the gantry are linked under the table.
Have dual screw with one nema34 1200 oz per screw.
One of my problem is the table top is built with aluminum extrusion and flex a bit since it is not supported but at both ends.
Cannot add legs under the table since there is a link between gantry.
What is opinion, more rigid table or joined gantry.
Jeff
Old 03-22-2011, 08:51 AM
robe_uk's Avatar
robe_uk is on a distinguished road
Could you post a picture of your setup? But i'd say as you are driving the gantry with duel screw you do not need to tie it under the table, if you are having problems with the side of the gantry splaying out then you need to beef up the gantry sides.
This will then allow you to beef up support to the table.
rob
I'll get it finished sometime after I start it.....
Old 03-22-2011, 10:36 AM
ger21's Avatar
The benefit of dual motors is that you don't have to join the sides under the table.
Go for the more rigid table.
Old 03-22-2011, 11:48 AM
Thanks for the reply guys.
Will post some pictures of my setup to better understand.
Will be back.
Jeff
Gantry Vs XY table fahque99 DIY-CNC Router Table Machines 1 01-26-2009 02:22 PM
open table vs closed-table gantry setups nicanor76 DIY-CNC Router Table Machines 2 04-21-2008 12:35 PM
Gantry or table? skaha DIY-CNC Router Table Machines 5 10-11-2006 11:06 PM
Gantry or Table?? jetstuff DIY-CNC Router Table Machines 6 02-16-2006 08:39 AM
Moveable Gantry or Table? barkster DIY-CNC Router Table Machines 4 11-08-2004 07:26 PM
