Old 03-21-2011, 09:27 AM
vlad1983 is on a distinguished road
Exclamation cnc for stainless steel engraving + few other questions
Hi All,
I'm building cnc router with friend's help and we would like to know
what material to use for machine body and what for the movable parts?
Machine will have 70x50cm work area and will be used for steel,
stainless steel, aluminum and brass engraving. Depth of engraving on
steel and stainless steel will be 0.1 to 0.3 millimeter on 2 millimeter
sheets.
Also what router (kress/bosch/dremel/makita) or spindle would you
recommend for this type of engraving, and what coolant.
Stainless Steel Engraving CNC602 Videos 1 12-31-2010 04:57 AM
stainless steel cboys22 General Metalwork Discussion 9 11-02-2010 09:50 PM
stainless steel engraving machine mar-tec Engraving Machines 1 05-20-2010 01:02 AM
Need Help!- Stainless Steel waterfxmatt DynaTorch 2 02-09-2010 01:00 PM
Is stainless steel CNCadmin Hard and High Speed Machining 12 10-17-2003 08:19 AM
