Hello, I have a newly built cnc machine, it all works fine, but when you bring the machine to a stop the motors vibrate heavily shaking the ballscrew and making one hell of a racket. It stops if you jog the machine a few mm. What could this be? They're nema 23's 270 oz by the way running on mach 3. Gaz. |
| Hi Gaz, If you haven't already double check all connections at both motor and driver ends. Check for stray strands of wire shorting against other pins. If you using single PSU dont daisy chain the power from one drive to the next, take single lead to each drive. Are you using correctly grounded shielded cable.? |
| Heavily CNC converted Opti BF 20 Vario | JMI80 | Benchtop Machines | 76 | 04-15-2012 08:34 AM |
| Need Help!- Motors vibrating machine! | blake374 | Mach Software (ArtSoft software) | 5 | 03-06-2011 02:29 PM |
| TM 2 Vibrating | bigbaz | Haas Mills | 13 | 05-26-2009 08:48 PM |
| ATC with Stationary tool | delectrol | General Metal Working Machines | 9 | 03-23-2008 08:25 PM |
| Belt Drive Gantry with STATIONARY motors for X and Y Axes | NEATman | DIY-CNC Router Table Machines | 0 | 12-19-2007 09:53 AM |
