I'm preparing to build a slightly-modified version of the 4x4 kit offered by Fine Line Automation (FLA-300), and am hoping to tap into some of the vast experience of the membership regarding the Z-axis as well as cable management on the gantry. The first modification is the use of the high z-axis plate, (hopefully) giving me 12" of travel on the z-axis before flexing/twisting comes into play. Use of this high Z-axis plate puts the Z-axis stepper motor atop the moving portion of Z-axis. The second mod is a lower bed, as shown in the rendering below, allowing me to rout foam blocks up to 12" in height. Problem #1 is that I'll also be working aluminum on this machine, so it has to pull double duty. I have the feeling that to work the aluminum cleanly and accurately, I want to be somewhere in the middle of the z-axis travel or shorter (as opposed to at almost the full 12" downware extension of the Z). Can anyone suggest an elegant way to handle this? Problem #2: Since the z-axis stepper motor is atop the moveable part of the z-axis assembly, it travels up and down as well as across the y-axis, making the use of a cable chain impossible (I think...). The rendering below shows the z-axis assembly in 2 extremes of travel (the machine won't have 2 independent z-axis ). To further complicate things, I'll also have to accomodate 2 cooling lines for the spindle along with the normal wiring to the z-axis stepper and wiring to the spindle.I'm sure others have vertically-moving Z steppers and water-cooled spindles; Just wondering how you handled the cable mamagement along the gantry. I'm looking for something clean and self-contained as I'm hoping to avoid cables and hoses dangling down from my ceiling to the machine Thanks! --Mark Last edited by Zuni; 03-18-2011 at 09:17 PM. |
| I made a small router with back-to-back mounting using something very similiar to the high z-axis plate as marketed by CNCRouterParts.com. Although the z-axis motor moves up and down, I was able to make an echain for the cables that works just fine. Here's a link to a YouTube video: YouTube - Small Router cable management.MP4 Your Z-axis is most rigid when the spindle is closest to the bearings. I would suggest that you make a rigid structure to mount on your platform that will raise the base 6 (or more) inches to effectively shorten your Z axis when you cut aluminum. Although you may have already taken this into account, I would suggest you consider beefing up the moving gantry supports (and consider using the longer bearings) because they will flex as well as the z-axis itself when you suspend a spindle 12" down. Last edited by DonFrambach; 03-18-2011 at 11:54 PM. |
| Thanks. looking at your video, I realize that I left out a key piece of information on my cable management dillema: The Y-axis is a rack and pinion unit, so the Y stepper moves along the gantry in concert with the Z carriage, but at a fixed height, while the Z stepper is going up and down above it: ![]() I didn't show it in the rendering, but the gantry beam will be gusseted at the moving gantry supports to minimize the leaning tendency when the z-axis is fully extended. My initial thought for raising the bed 6" was to mount some tabs, or better yet a calibrated (leveled and trued) rail, along each inside support of the machine, so I can slide in another higher bed in and out when needed, but that seems like a pain in the butt and is one more (large) piece to store somewhere: |
| I think this is what you're looking for. Here's a beautiful router with moving gantry and moving Z axis motor with very clean cable management. http://www.cnczone.com/forums/diy-cn...ys_router.html To whet your appetite, here's a photo from his build log: |
| Thanks for the tipoff about the cable management. --Mark |
| DYI 4th axis advice? | Spinnetti | General Metal Working Machines | 6 | 01-17-2011 10:47 AM |
| Need Help!- Advice on 5-Axis and ERP | Lawsonmh15 | General Metalwork Discussion | 0 | 01-10-2011 01:27 PM |
| Need Help!- Advice on 5-Axis and ERP | Lawsonmh15 | General Metal Working Machines | 0 | 01-10-2011 12:45 PM |
| Advice on 3 Axis Kit | spjuenger | Joes CNC Model 2006 | 1 | 08-31-2009 04:19 PM |
| Z axis need advice | Kev | DIY-CNC Router Table Machines | 2 | 07-19-2007 07:11 PM |
