Old 03-17-2011, 03:02 AM
adambrum is on a distinguished road
initial specs for new build
Im finally going to start designing and building my cnc router, I have a general design in my head and what i want the machine to do but im not so sure on the details.
The machine will have a cutting area of 20" x 50" with about 3" z-axis, normal gantry type machine with a single ballscrew for y-axis.
I will be machining mainly acrylic,alloy and ply.
I have decided on supported rails all round, would have liked hiwin but cost was too high.
So here's the first draft of specs.
20mm supported rails for x and y
16mm supported rails for z
20mm ballscrew for y
16mm ballscrew for x and z
120 x 30 alloy extrusion for x,y axis frame
20mm plate for uprights and z-axis
So there's the basic spec, Any thoughts ?
Thanks Adam
Old 03-17-2011, 08:15 AM
adprinter is on a distinguished road
What I did on my machine
Hello,
I too originally started out with just a general desire to build a machine with about a 3'x4' table. No plans to work with at all. I just became hooked on the idea of CNC after seeing You Tube videos. What a cool device! Output files from a computer, just like output to a printer, and it carves out the part!
That was in October, 2008. Have a look at the attached file, and it may help you in your design.
Best computer specs / build for running Solidworks, please advise swingwing205 Solidworks 36 02-15-2011 09:03 PM
Help in initial setup. hjl4 Viper Servo drives 30 01-18-2011 04:20 AM
Newbie- New and looking for initial help rolljordan Want To Buy...Need help! 0 10-24-2008 06:51 AM
Newbie- Initial Projects? rgarrett7 Mini Lathe 1 10-06-2008 07:00 PM
Stepper Specs (Was Servo Specs) plexer Stepper Motors and Drives 1 09-29-2005 09:28 AM
