Old 03-14-2011, 05:16 PM
Justin Cavender is on a distinguished road
soft limits?
How do i set up soft limits in mach3 and can i set a home without switches? if so how do i do both of these?
Old 03-14-2011, 06:02 PM
ger21's Avatar
You can home without home switches, just click Ref All button, and it will set your home position wherever the machine is at that time.
Before I had home switches, I would jog my machine against it's hard stops, and Ref All there, so I had a repeatable home position.
Softlimits positions are set in Config > Homing/Limits, and toggled on and off with the Softlimits button on the run screen.
Old 03-14-2011, 11:48 PM
S3MIH3MI's Avatar
S3MIH3MI is on a distinguished road
I try to send all 3 axis home before I close the program, but in the event I need to home from scratch I do the following....
Manually move each axis to it's hard stop
Start Mach3 and the controller
Set the jog mode to step and .1000 for stepping distance
Now I jog each axis twice and this will set it off the hard stops by .2
Then close and restart Mach3 and Ref All
Old 03-15-2011, 06:22 AM
so how do i input the data into the soft limits? Do i just input where i dont want it to go past or do i jog it over and set it?
Old 03-15-2011, 06:36 AM
ger21's Avatar
Just type in the numbers
Need Help!- Okuma soft limits Carlton Jenkins Okuma 6 02-14-2012 06:58 AM
Need Help!- Mach 3, Soft Limits Droider DIY-CNC Router Table Machines 3 11-25-2009 04:18 PM
Need Help!- VF-4 Zaxis soft limits Sam Mcquern Haas Mills 5 01-20-2009 07:25 PM
Problem- soft limits zimba43 Mach Mill 2 04-01-2008 04:18 PM
Question about Soft Limits??? Dennis Fletcher Mach Software (ArtSoft software) 3 07-31-2005 01:07 PM
