Old 03-13-2011, 11:12 AM
jzurek is on a distinguished road
Probotix SideStep Chopper Driver
Hello everyone! First I would like to thank you for helping me resolve my other issues. Here comes the next one:
I purchased a Probotix SideStep Bi-Polar Chopper board for my A-Axis
SideStep Stepper Motor Driver - Bipolar Stepper Motor Driver
The user manual shows an enable pin, but when I look through the Mach3 setup information from Probotix, it says the SideStep does not use an enable pin. I'm confused and do not want to destroy anything.
Has anyone used one of these boards and wired it to a BOB? If so, can you advise if you used the enable pin?
Thanks in advance. My electrical is almost complete! Now on to finish the machine design. Pics coming soon!
Jeremy
Old 03-13-2011, 02:49 PM
Walky's Avatar
Walky is on a distinguished road
I have the Probosteps (Probotix's unipolar drivers) and they work without any need of configuring the enable outputs in Mach3. I got Sidesteps like yours for my smaller machine a coule of days ago but I haven't had any time to mess with them (moved to a new house yesterday); I'll keep you informed as soon as I try them, but I'm 99.9% that not using them will not damage your boards, and I think the drivers will probably let you move the motors without using the enable pins. If you want a first-hand answer, send an email to Probotix, they always answer my emails pretty soon (it seems they are moving to a new facility, so it might take a little longer right now).
Old 03-17-2011, 10:03 AM
Walky's Avatar
Nevermind, I overlooked the fact that neither the Sidestep nor the Probostep uses the enable pins. Now I'm 100% sure you can use your drivers without any problems, and without the need for enable pins.
Probotix ProboStep stepper driver cor bit Stepper Motors and Drives 1 08-25-2010 04:45 PM
HobbyCNC Unipolar Chopper Driver Kit! HobbyCNC Product Announcements & Manufacturer News 1 11-09-2009 08:40 PM
20A L297 Unipolar Chopper Driver AndersG Open Source Controller Boards 2 09-21-2009 10:57 AM
Probotix Driver GM2008 CNCzone Club House 0 11-20-2008 11:30 AM
Difference between 4AUPC Chopper and HobbyCNC PRO chopper driver board shreifali CNC Wire Foam Cutter Machines 1 02-09-2007 12:09 PM
