Old 03-11-2011, 08:53 PM
Justin Cavender is on a distinguished road
tool offsets and tool changes in mach3
Can anyone tell me the procedure for height offsets. and can you setup some kind of tool change routine for mach3?
Old 03-11-2011, 09:20 PM
ger21's Avatar
The easiest way is to use an auto tool zero to let Mach3 set the tool height. Big Tex's version allows you to auto zero after a tool change.
http://www.cnczone.com/forums/mach_w...r_big-tex.html
My 2010 screen has a modified version that auto zeroes during a tool change.
Old 03-12-2011, 08:07 AM
Ger where do i download it? and what is the process for letting mach 3 set the tool height? I have done it on a haas mill where you touch the tool off and hit tool offset measure is it similar in mach3? I want to be sure of what im doing before i make cuts with my new machine thanks
Old 03-12-2011, 08:19 AM
ger21's Avatar
Links to the screens are at ArtSoft USA - Screensets
If you want to use the stock screen, you'll need to modify it to work with the macro's that are posted in the thread I linked to.
You need to have a plate wired to the probe input in Mach3, and the tool needs to complete the circuit when it touches the plate. For tool changes, you need two plates, one you place on the workpiece, and another in a fixed location on the machine, that is used as a reference position to get the length of tools after tool changes.
There's more info on Auto Zero maro's here.
http://www.cnczone.com/forums/cnc_wo...tool_zero.html
Problem- 21iT: Using 2 offsets for 1 tool:Machine stops for tool change gnmachine Fanuc 4 02-01-2011 08:10 AM
best way to maintain tool offsets - tool set changes pld0vr Haas Mills 3 05-22-2010 01:28 PM
Need more tool offsets ChattaMan Okuma 16 12-07-2009 05:36 PM
setting the tool data and the tool offsets Michael82 Mazak, Mitsubishi, Mazatrol 6 01-23-2009 01:50 AM
Tool offsets plateroomred CamSoft Products 7 05-28-2005 02:43 PM
