Old 03-11-2011, 02:16 PM
tkubic is on a distinguished road
Cam Software
What cam software does everybody use?
Things I'd like:
  • $200 range (I am a student)
  • 3D capable. for more complex foam models
  • spits code out that Mach3 can handle (probably not a big deal)
I would like to use Solidworks/ProE, but that isn't a must if i can make the $200 range.
RhinoCam student package seems closest that I've found so far, but I don't know many options.
Any opinions?
Old 03-11-2011, 02:34 PM
awerby is on a distinguished road
Everybody's doing different things, so their choice of CAM software might not be a unanimous one. If you are building solid or surface models and exporting them as STL with foam carving in mind, RhinoCAM is a good choice (assuming you've got Rhino and it meets your needs and budget.) Another program you might look at is DeskProto; the "lite" student version is pretty inexpensive, quite simple to use, and will probably do everything you need, at least while you're getting started with all this. You can try their working demo for a month before it times out, which should give you a pretty good idea of how the process works: DeskProto offers rapid prototyping using an affordable cnc milling machine: DeskProto is 3D cam software for model making. Wait until you've got a CNC mill, or access to one, before downloading it.
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
Old 03-12-2011, 08:47 PM
gjhammer is on a distinguished road
I know I've seen many experienced CNCZoners around here recommend MeshCam (http://www.grzsoftware.com/) and it is less than $200. But I do not have any personal experience with that software.
http://build1.cncdiaries.com
http://www.cncdiaries.com
Old 03-18-2011, 07:54 PM
My machine is up and running now.
I've been fiddling with Lazycam, but when trying to cut out some of the dinosaur puzzles I have many issues with cut paths and orders, also many issues with the software coming back later after the part is free and trying to cut stray vectors out causing damage to the free'd part.
After already spending so many hours fiddling in corel draw then exporting to lazycam I'd like something that I can go from cad model to cam software with a little more ease.
I suppose I'll start hoping on some of these free trials and testing out more of them.
Old 03-18-2011, 08:08 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
CamBam CNC Software
cambam is low cost and he also offers a free version that will be capable of getting you started
and as was mentioned deskproto has a hobby version which is pretty well priced
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 03-18-2011, 09:02 PM
atwooddon is on a distinguished road
I would also add my recommendation for CamBam. It is a combination CAD/CAM program. The CAD functions are for 2.5D drawing, limited 3D drawing capability. However, you can import DXF and STL 3D drawings and generate 3D CAM code with CamBam. The support is great and the author is very active in the forums. There is a free version which is an older version, you can also use the current version 40 times with no restrictions so you can try the software with no restrictions.
Don
Old 03-18-2011, 09:18 PM
HereinCS is on a distinguished road
I'm trying to learn Rhino. I bought the madcam 5 axis for less than $200 using a student discount. Supposed to be very good, though I've yet to use it.
Old 03-18-2011, 09:41 PM
dertsap's Avatar
Gold Member
from what i understand the madcam is pretty good , at 200 you can't go wrong
Old 03-19-2011, 12:47 AM
AssassinXCV is on a distinguished road
I'd go with Meshcam, their trial is amazing. It's WAAAAY Cheaper than Vectric's software, and, it allows for 4-AXIS MACHINING!!! WOW!!! Developer also gives alot of support which is always a good thing. Vectric's software price is double Meshcam's but only does 3-AXIS.
Old 03-19-2011, 06:10 AM
ger21's Avatar
Originally Posted by CNCmakers View Post
Master CAM
He said $200, not $5000.
  #11   Ban this user!
Old 03-20-2011, 10:57 AM
hemsworthlad is on a distinguished road
Master CAM
Pirecy is a criminal offence.!!
  #12   Ban this user!
Old 03-21-2011, 08:37 PM
beermkr is on a distinguished road
So is bad spelling (piracy)
Mike Pensinger
Chief Brewer, The River Company Restaurant & Brewery, Inc. Radford, VA
Newbie- Need software advice...What software can import .JPG files? pairofjacks General CAM Discussion 7 06-01-2011 06:18 AM
Build Thread- machine control software & cam software grttt3 General CNC (Mill and Lathe) Control Software (NC) 2 05-06-2010 01:49 PM
Just IN- MIE Solutions - Free Quoting Software Trial Software available MIE Solutions Product Announcements & Manufacturer News 0 01-07-2009 10:42 AM
First post in the software dept. Free cnc software? runinbymdnt General CNC (Mill and Lathe) Control Software (NC) 2 02-06-2007 09:49 PM
