Old 03-10-2011, 03:01 AM
$hantan is on a distinguished road
Which driver?
To
The Demigods, Gurus, Mortals of CNCZone,
I've finally started ordering the parts for my 3 axis (hopefully upgradeable to 4 axis) machine. Which means from now on, I'll be asking you guys some extremely stoopid questions ; so please bear with me and thanks in adv.
The XTravel and the YTravel of my machine is 2400mm(~94.5") and 1600mm(~63") respectively. I am planning to use the Gecko G210 for the X axis since I've read somewhere that if more number of pulses need to be sent, then the G210 is preferred over the G201.
My question is, should I use a G210 for the Y axis as well, or can I get away using a G201?
Thanks again.
PS: Not sure if this thread should be here or in the GeckoDrives forum.
Newbie- Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver? joprinz General Electronics Discussion 4 04-28-2011 03:57 AM
Problem- TM 2x2 driver problem - wants to put 64 bit driver in ??? ronsii Torchmate 1 12-27-2010 04:10 PM
Do i need a BOB for this driver? CNCishard Stepper Motors and Drives 4 12-23-2008 03:48 PM
single axis driver and a b.o.b.,or multi-axis driver board .xXACEXx. Stepper Motors and Drives 3 07-02-2007 11:13 PM
STEPPER DRIVER FAQ {Stepper/driver amp per phase match. huios Stepper Motors and Drives 0 08-27-2006 08:43 AM
