Old 03-08-2011, 05:14 PM
Justin Cavender is on a distinguished road
Fla100 mach3 config
i just built an Fla100 from fine line automation is there any way I can manually input steps per unit as opposed to measuring the move and is there any video tutorials on configuring mach3?
Old 03-08-2011, 05:53 PM
ger21's Avatar
ArtSoft USA - Video Tutorials
What screws are you using, and what drives?
Old 03-08-2011, 05:56 PM
1/2 10 screws with a gecko g540 drive
Old 03-08-2011, 05:58 PM
ger21's Avatar
20,000 steps per inch.
200steps per motor revolution, times 10 microsteps, times 10 turns per inch.
Old 03-08-2011, 06:49 PM
where do i input this I think that is what is input on th emotor config but over the 36 inches f travel its the dro says it is something like 800 inches
Old 03-08-2011, 07:20 PM
ger21's Avatar
First, go to Config > Select Native Units, and select Inches.
Close, and restart Mach3.
Then, go to Config > Motor Tuning, and set the steps per unit for each axis, and click Save. Then close and restart Mach3.
Then you'll need to go back into the motor tuning screens and adjust acceleration and velocity for each motor. The up and down arrow keys should jog the current motor while in the tuning screen.
Old 03-08-2011, 08:48 PM
CNC Lurker's Avatar
CNC Lurker is on a distinguished road
Is that single start, 5-start or what? That will make a difference.
Mine is a 1/2-10 5-start so these are my settings:
Steps per = 4000
Velocity = 220
Acceleration = 60
After you make those changes, you may have to close Mach and re-start it for the changes to take effect.
http://paul-flores.com/
Old 03-08-2011, 08:49 PM
yes they are 5 start screws
Old 03-08-2011, 08:59 PM
ger21's Avatar
Then make that 4000 steps/unit
Old 03-08-2011, 09:19 PM
CarveOne is on a distinguished road
800 inches sounds like Mach3 is in metric mode (the default for new installs I think) and you are entering inch mode numbers. 36 inches is 914.4 mm. Check that in the Configuration menu. CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Mach3 config files Konstantin Mach Software (ArtSoft software) 0 05-15-2009 01:42 PM
Config Mach3 for coolant BrassBuilder Benchtop Machines 4 08-19-2008 05:53 AM
Steps per/mach3 config bp092 Gecko Drives 2 02-22-2008 12:49 PM
Need Help!- Config Mach3 rex2 Machines running Mach Software 0 01-26-2008 03:52 PM
G-Rex100 and Mach3 Help on I\O Config cybertek Mach Software (ArtSoft software) 2 01-02-2007 10:39 AM
