Old 03-04-2011, 08:58 AM
jpike10's Avatar
jpike10 is on a distinguished road
laser cut MDF??
I was Leary about trying this but my cnc's are tied up with paying jobs.
I am building a clone of Patrick Hood-Daniel's Black toe 2x4. and cut most of my Mdf on a laser using nitrogen as a shielding gas (with no fires!!yeah)
It only took 8 minutes to cut cut a 4x4 sheet worth of parts. the only downside is the edges are blackened and stink like hell. nothing a little sanding wont cure.
I have to say this hobby is getting addicting i am only 1/2 to 3/4 thru this one and i am already designing a 80/20 machine.....I have learned a ton on this site and look forward sharing my builds.
the solid model is just a rough design
Old 03-04-2011, 10:08 AM
wcarrothers1 is on a distinguished road
interesting the thought of using a sheilding gas. really the only way to avoide heat/fire. Good idea..
b.
Old 09-26-2011, 08:51 PM
kiwifred is on a distinguished road
Please can you supply details of the laser you have used. I am looking for exactly the same kind of capability for a blacktoe machine.
Old 09-26-2011, 10:32 PM
Benonymous's Avatar
Benonymous is on a distinguished road
Why bother sanding off the carbonized MDF? Why not just give the edges a good soak with polyeurethane or epoxy. It might be a bit messy but it would seal them up a treat :-)
Old 09-27-2011, 06:46 PM
Pplug's Avatar
Pplug is on a distinguished road
I too would love to use a laser to cut mdf. What power and type of laser did you use?
Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
Old 09-27-2011, 08:10 PM
wshappy's Avatar
wshappy is on a distinguished road
I think the Co2 laser cutting machine is much better, but should make attention, don't make the speed too slow, otherwise it will make the edge burn or turn to black. what is the cutting thickness of your MDF?
Old 09-28-2011, 10:25 AM
Pplug's Avatar
Most mdf purchased at large lumber retailers in the USA come in 1/2" and 3/4" thicknesses.
wklaser(Gweike laser) new laser engraver display tina Product Announcements & Manufacturer News 2 09-21-2011 06:20 PM
Need Help!- Laser table wont lift up (GCC/ Laser Pro Mercury II) aussiemate Laser Engraving & Cutting Machines 6 03-03-2011 07:47 AM
Cost-effectective 445nm laser for laser show cni Product Announcements & Manufacturer News 0 12-20-2010 01:01 AM
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
