Old 03-04-2011, 01:38 AM
victoria_jay is on a distinguished road
Smile New CNC router build log
I am working on building up a CNC router. it is gantry style. I am using aluminum flat bar to build a structure frame.
linear motion parts in a package are ordered from ebay seller:happylinearmotion2008
spindle are ordered from ebay too. I will keep posting the pictures regards the work I have done on this machine.
Old 03-04-2011, 02:18 PM
Post continue
The half inch thickness and six inch wide 6061 aluminum flat bar was used to built up z-axis and y-axis.
Old 03-04-2011, 03:09 PM
hemsworthlad is on a distinguished road
Pictures say a thousand words.!!
Old 03-04-2011, 09:28 PM
mrmartyman7 is on a distinguished road
building my first cnc router too
I am new here too !
I was posting on another site but it was very dead to say the least.
I'm building my first 12X36 INCH machine out of mdf.
I'd like to see pictures of what you are building sounds interesting.
Old 03-08-2011, 02:14 PM
Thanks you guys for reply. I will post some pictures about my machine soon because I am busy on other business these days.
Old 03-21-2011, 09:03 AM
pictures
I have only been able to do a few things to my machine this month , working on the gantry I had to shave a 32nd of mdf material from top and bottom af gantry to bring the sides in so they took up the slack that caused enough play to make travel sloppy.
I have than done now just need to drill the holes for the bottom dowels and bolts , the top is done . When I get this done I need to work on cross members on the bottom of gantry that will attach to the lead screw nut.
My real challenge begins when I map out the electronics although I have a few components I don't know enough about the controls to even think about starting . Where can I find help ?
If I post pictures of what I have collected so far can someone advise ?
Here is a picture of the machine so far.
these are some pictures of the stepper motor components I have trying to figure what else I need next for a power suppy(s) any help would be great.
Old 03-21-2011, 09:06 AM
If anyone has an electronics plan to share using components I have would really be appreciated.
Old 03-21-2011, 02:50 PM
I looked the web site of your controller board vendor. I can not find any maual or instruction about the wire for this board. Did they mail you some info. when you bought this board?
Old 03-21-2011, 04:57 PM
thank you for your reply
I will keep trying
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 07:51 AM
4´x 8´router build lamicron CNC Wood Router Project Log 2 08-08-2008 12:21 PM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 10:33 AM
