Whats the purpose of having a dual shaft stepper? Unless you where using both ends to drive something. I am going order my electronics tomorrow and have been browsing Keling's site and all of the G540 kits come with dual shaft motors. I would really like a single shaft. Whats better a 4 wire setup or 8? On one of the kits I noticed that if you bought everything separately it was $40 cheaper. Why, I thought there was usually a price break if you bought a kit. Still torn between a nema 23 kit or a 34. There is only a difference of 78 oz-in's of torque between the kit, is that a noticeable difference. I would really like to stick with a nema 23 kit because the motors are physically smaller and I could save around $100 also. My machine is only 24"x48" all out of aluminum, gantry weight shouldn't be no more than 40-45lbs. I am also using 1/2-10 5 start screws, think I could get by with the 23's? I am going to get this project underway next weekend and plan on having it done in a couple of weeks. I will start an official build thread if anyone is interested. Thanks Guys |
| I'm not an expert on stepper motors, but 3 uses come to mind: 1 - A damper can be installed to balance the motor to lessen resonance and prevent your motor from stalling. 2 - A handle can be installed to turn the motor (while power is off) for position adjustments or moving the different axis without having to power up the machine. I have machines with options 1 and 2. A 3rd possible use is mounting a gear to drive another lead screw for a dual drive machine, running both lead screws with the same motor. I am sure there are other uses, and more technical explanations for dual shaft motors. Hopefully others have more info. |
| Commercially built dampers are expensive. Solsylva has a page on making your own: Inertial Dampers~Solsylva CNC Plans And these are the least expensive but highly functional handles I've come across: CNC Stepper Motor Crank Handle for Manual Positioning - eBay (item 330343030746 end time Mar-29-11 10:44:30 PDT) |
| More damper info here. http://www.cnczone.com/forums/steppe...tml#post256639
| I think I will get the kit from cncrouterparts.com because the motors in the kit are single shaft. Does anyone know situation with the resistors worked out? Are the current kits that are being shipped out correct? Thanks Guys |
#10
| JJacstcy, Glad you're considering our motor kit. We do have adapters coming in at the end of next week that will be supplied to any of our customer who have had trouble with the current set resistor. We take a lot of pride in supporting our products, which is why this whole resistor issue sort of caught us off-guard. In the 2+ years we have been selling our system, we've heard very few complaints, as the problem only seems to affect some small percentage of drives. I just sent Marcus an email to see if I can get an update on testing at Gecko as well. I won't speak for them, but they are also a very customer-focused company, so my gut tells me they'll be working something out in the near future. Regardless, until then and beyond, we'll guarantee a working solution from CNC Router Parts. Best regards, Ahren CNCRouterParts |
#11
| Thanks for the reply! Are the adapters being shipped with the new orders, or is it just a wait and see if you have a problem type of thing? I have come across many threads that you have posted in and I know already how you stand behind everything! You have the nicest kit out there! Thanks |
#12
| The adapters will be going out on an as-needed basis, or to those who request them specifically, since the kit is a little cleaner without them and usually doesn't require them. That being said, if you're uncomfortable with not having them, I can certainly send some with your order. Best regards, Ahren CNCRouterParts |
| Single vs dual ballscrews? | MechanoMan | DIY-CNC Router Table Machines | 59 | 05-01-2012 11:34 PM |
| Dual Shaft Gearbox | Mcyoda | Mechanical Calculations/Engineering Design | 17 | 05-16-2010 09:36 PM |
| Dual NC controls within a single machine | Jim Shaper | General Metal Working Machines | 14 | 06-01-2009 12:02 AM |
| Single vs Dual Lead Screws | Cold Fusion | DIY-CNC Router Table Machines | 5 | 03-08-2009 04:26 PM |
| Dual and single shaft stepper motor differences? | Menatep | Stepper Motors and Drives | 5 | 04-09-2007 10:22 AM |
