Old 03-02-2011, 01:04 PM
bandtank is on a distinguished road
i cut a channel in my table
I need to vent to people who understand. I was cutting holes and pockets for my fixture mounts and forgot to raise the z axis. I was doing the G-code manually as it was really simple stuff. Crap
I guess this is where I will put my touch plate. It was going to go somewhere else but I can't have this big ugly cut in my table.
It was moving at 150ipm to the next location. It moved 2.130" before I was able to stop it with the e-stop button. I normally keep my hand on the button at all times when I'm doing manual code execution, but it was at my side this time. I am surprised I got to it that fast - 0.852 seconds = 2.130" @ 150ipm.
Sigh...
Old 03-02-2011, 01:47 PM
br1 br1 is offline
br1 is on a distinguished road
Sorry to hear that, I hope it only got your pride, I remember once a guy down at the shop did that with a Mori Seiki using a kennametal kssm indexable 8 inch shell mill about 1/2 inch deep about 1 inch long on a job that took several hours to set up. I thought I was looking at a ghost, So I know your not alone, and it is only wood, could have been worse.
Old 03-02-2011, 02:29 PM
Ouch. Yeah, that sounds much worse. Thankfully I didn't cut my ball screw in half (it is right below this cut) and the bit didn't break either. You can see it was flexing because it straightened out when it stopped moving.
Live and learn.
Old 03-02-2011, 09:53 PM
neurofen's Avatar
neurofen is on a distinguished road
whats anything without a wound or 2, looks better already.
done a good job. _
Old 03-03-2011, 03:19 AM
jeffrey001 is on a distinguished road
Talking
If you do the same thing to all other holes, they will look all the same and nobody will never know
Seriously, I'm sorry for that.
Jeff
Old 03-03-2011, 05:12 AM
jjacstcy is on a distinguished road
Bondo......
Old 03-03-2011, 11:19 AM
Barnhart is on a distinguished road
Bondo is great i have done this a couple of time in the suction bed of my router.
Old 03-03-2011, 03:37 PM
Zygoat's Avatar
Zygoat is on a distinguished road
you could always make it into a design, or a feature, half of the coolest stuff i ever did came from having to cover up mistakes. (sometimes they can be good things) the telephone was an accident.
you could also use a t slot cutter and make them all pockets for bolts so you can slide the bolt in and it wont spin, then you can use them as tie down points.
or you could flip the whole sheet over.
Old 03-03-2011, 07:28 PM
neurofen's Avatar
cigarette holder?
Old 03-03-2011, 11:30 PM
crane550 is on a distinguished road
You should see MY cut up table...
  #11   Ban this user!
Old 03-04-2011, 06:59 AM
CarveOne is on a distinguished road
Save some MDF dust, mix it with a drop of white glue or carpenters glue until it is a semi-dry paste and plug the hole and slot with it. When dry, sand it flush. Cheap filler.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
I/O Channel Parameters Probe Guy Fanuc 4 11-06-2008 01:33 AM
Cutting in channel WEDM Laser Engraving & Cutting Machines 1 07-18-2008 11:17 AM
80/20 versus u-channel SteveT44 DIY-CNC Router Table Machines 4 11-19-2005 04:39 PM
IRC channel for EMC Dan Falck LinuxCNC (formerly EMC2) 0 12-18-2004 11:03 AM
Two steppers from one channel? m1911bldr General Electronics Discussion 1 03-29-2004 08:30 PM
