Old 03-01-2011, 07:03 PM
Riceburner98 is on a distinguished road
Anyone using an "Avenger" ATC spindle yet?
The only 2 threads I found on the 'Zone are from the maker of the thing, and besides 1 video doing a tool change and some nice pictures on their website I can find ZERO information on anyone actually using one..
Link ->
Avenger ATC Spindles
My plans keep evolving for the beast of a machine I'm going to build (only 32" x 18" for now due to space constraints..), I think the gantry could hold up a truck. I've been looking at Colombo and Perske spindles lately, and for some reason in my warped head I'm justifying the cost.. (my boss built a 6' 8020 gantry machine years ago with a Colombo and tells me about the rooster tails of hot aluminum chips he'd get going full-bore through .25" stock...)
A manual 3HP Colombo (new) can be had for $2,300, plus a drive.. Granted, I'll only have 120v available for a (long) while so I doubt I can even use the thing to it's full potential.. One of the places that has Colombo's for sale is Blurry customs, and I saw the "Avenger" auto tool changer they have. Once again, my damaged brain is justifying the cost (~$3,000 -ish with 6 tool holders and a 2HP Bosch router for a drive motor).. But it freaks me out a little that I don't even get 1 hit on Google besides 1 Youtube video and their website selling it..
On the other hand, some time back I bought an X2(?) R8 spindle shaft and some really high quality NSK spindle bearings and designed a spindle in my head.. No ATC, but how hard can that be? (LOL!!! Kidding!) Should I just dump $2,500 into having a machine shop make me a housing and hope the shaft doesn't vibrate like hell @ 15,000 RPM?
I'm not exactly made of money, but I did just get a bonus at work... Hate to blow it on something that doesn't quite work as expected though. (like the spring-loaded quick-change tooling I bought for the Taig a few years back - runout was bad enough to snap small tools..)
Any thoughts? I'll have to post my SolidWorks renderings of the gantry mill (router? I don't really cut wood...) here if I ever finish changing the thing.. Right now it's got an 8020 main beam (48" 3060 - 3" x 6") with a 5/8" aluminum plate on top of that to mount the X axis slide.. Super-overkill! Using a Taig spindle on it just seems a little under-whelming..
Old 11-20-2011, 12:33 PM
jharvey407 is on a distinguished road
I'm surprised that no one has replied.
I am in the same situation that you're in. I am upgrading my router to a larger frame, and would really like a larger spindle. Also an ATC would be very nice.
Have you decided which router/spindle you are going to use?
Did you find any information about the Avenger?
Old 11-20-2011, 07:52 PM
Never saw anything more about the Avenger spindle online, though I haven't looked in a while.. As usual the build of the machine got delayed due to work, funds, and my wedding.. Hoping to get time over the winter to do some more work on it. A guy at work has a 4'x8'x3/4" slab of anodized ground aluminum he said I can trade my slightly warped slab for, i just have to go cut it.. That should make a great base!
Of course now that the wedding is over it's not "my" money any more, right? So we'll see what I have left for spindle $$ when the time comes....
Old 11-22-2011, 11:12 AM
giz giz is online now
giz is on a distinguished road
I haven't heard much on the Avenger. I've been searching night and day for an affordable, compact ATC spindle but I just can't find one. The Avenger and the Chinese ATC spindles I am seeing are just too long for my design.
Old 11-22-2011, 12:30 PM
mactec54 is on a distinguished road
Riceburner98
I will be doing a ATC spindle starting early next year, the build will be on the Zone
Here is a link to a small one that I have just made for a customer, It is not a ATC
http://www.cnczone.com/forums/cnc_wo...dle_build.html
Mactec54
Old 11-22-2011, 04:58 PM
Originally Posted by mactec54 View Post
Riceburner98
I'm looking forward to your build. Will you be producing the ATC spindle for sale?
Old 11-22-2011, 05:13 PM
jharvey407
Yes they will be for sale
Mactec54
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Any spindle drive experts here? Tweak my "haas power" system bob1112 Haas Mills 1 12-13-2010 06:31 PM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
