i just receive my steeper motors form ebay i got cd also but... is all in Chinese how to connect these cables from steeper motors to the board i got 6 cables from each motor green,red,black,yellow white, blue and on the board i got "MIN GND MOUT" "XA- XA+ XB- XB+" " YA- YA+ YB- YB+" " ZA- ZA+ ZB-ZB+" "GND 12/36V"and then on power supply i got "v- v- v-" "v+ v+ v+" "ground N L" |
The power supply labeling sounds like the following: "v+ v+ v+" DC voltage positive output terminals "v- v- v-" DC voltage negative output terminals L 120 volt AC (black) hot wire N 120 volt AC (white) neutral wire Ground powerline ground |
It sounds to me like your driver board is set up to drive 4-wire bipolar stepper motors, and it is set up to handle 3 axes (X, Y, and Z). So, for the X-axis motor, the terminals marked "XA- XA+ XB- XB+" represent the four wires from the motor. A represents one motor winding, while B represents the other motor winding. Within the A winding, the + terminal represents one wire and the - terminal represents the other wire; ditto within the B winding, for a total of 4 wires to connect to the board. A 6-wire stepper motor can be used as if it were a 4-wire motor (by using 4 of the wires and leaving 2 of the wires unconnected - the trick is to figure out which wires to use and which ones to leave unconnected). First, you need to separate the wires into two groups of 3 wires each (the A group of wires and the B group of wires) - use a multimeter on the resistance ("ohms") scale to locate 3 wires that are electrically connected to each other. The remaining 3 wires should have conductivity within that group, but should not show a connection to the other group of 3 wires. Then, within each group of 3 wires, you need to figure out which 2 wires to connect to the driver board terminals, and the third wire you will just leave unconnected (but you will want to put some electrical tape on the end of the wire to make sure that it does not accidentally short out to some other wire). To do that, measure the resistance between each pair of wires (in other words, make 3 resistance measurements, for example, if you label the wires 1, 2, and 3, then measure the resistance from wire 1 to 2, then measure from 1 to 3, and finally measure from 2 to 3). The pair of wires that shows the largest resistance value is the pair of wires that you will connect to the + and - terminals for the A winding of the selected axis. Then repeat for the B winding of that axis. It's easier to do it than to describe it in words... |
| As far as hooking up the other terminals on your board, I'd need more information to be sure. You will at least need to hook up the V+ and V- terminals from your power supply, and you might also need to connect a lower-voltage (12 volt?) DC supply to power a fan and/or the logic circuitry on your driver board. |
| Hello Folks I have the same controller with the same 6 wires steppers. I tried to test the wires as described in your post , but i realized that i have no resistance between the Brown-Orange, and Blue-Yellow, and no connection between the red and green wires. Can someone help me to make my diy cnc work. i am just a beginner Thank you |
#10
| Make sure that your multimeter is set to the lowest resistance (ohms) scale, because you will probably be looking at small values of resistance in the windings. Here's what I just did with one of my motors. The motor had green, yellow, black, blue, red, and white wires. I started with the green wire and tested the resistance to every other wire (making sure that while I was doing the test, none of the bare wire ends were touching each other). The results from green were as follows: to white, no connection to yellow, 8.6 ohms to red, no connection to blue, no connection to black, 16.5 ohms. So, the result of this test is the following: 1) I believe that green, yellow, and black comprise one winding (call it winding 'A'), and just to make sure, I check the resistance between yellow and black, finding that it is 8.8 ohms. Therefore I conclude that for the A winding, my A+ and A- wires will be green and black, and I will tape off the yellow wire and leave it unconnected. 2) I also believe that red, white, and blue comprise the other winding (call it winding 'B'). For my next test, I will check the resistance from the red wire to the white wire, from the red wire to the blue wire, and from the white wire to the blue wire. I find the following: red to white, 8.8 ohms red to blue 16.6 ohms blue to white, 8.8 ohms Based on the results of this test: 3) I conclude that for the B winding, red and blue will be my B+ and B- wires, and I will tape off the white wire and leave it unconnected. If you can run a similar test, please post all of your results as I did here. |
| the encoders' wires itself | Khaled.Hosam | Servo Motors and Drives | 6 | 11-09-2010 06:16 PM |
| Stripping Wires | pntbllrsprky | CNCzone Club House | 1 | 07-13-2010 02:35 AM |
| need help id 8 wires | 15mgtar | Stepper Motors and Drives | 6 | 07-30-2009 12:53 AM |
| What wires to use? | studysession | DIY-CNC Router Table Machines | 2 | 02-21-2007 01:02 PM |
| Best way to keep wires out of the way | CuttersCov | DIY-CNC Router Table Machines | 3 | 11-02-2006 08:40 PM |
