Old 02-21-2011, 02:54 PM
HereinCS is on a distinguished road
CNC router to 3D printer
I'm thinking of adding 3D printing as a function to my desktop CNC router. Is this possible? What software/controller would I need?
Old 02-21-2011, 03:07 PM
Jesse B's Avatar
Jesse B is on a distinguished road
As far as I know, all you need is to add the extruder to the Z-Axis, and then have an extrusion controller combined with your standard stepper drivers. Checking out RepRap or Makerbot would be helpful.
Old 02-21-2011, 03:14 PM
bonmotwang's Avatar
bonmotwang is on a distinguished road
I think you will need CUT3D to do the multiple side cutting. That's is my plan anyway.
Old 02-21-2011, 03:17 PM
I'm looking at the makerbot site. The steptruder seems reasonable priced.
MakerBot Stepstruder
They use ReplicationG software however. It's on an Arnduino platform. How does this integrate with Mach3 and gecko drives?
Old 02-21-2011, 03:35 PM
bonmotwang's Avatar
What is the resolution this machine can do and how about the strength of the finished part.
I am using RedEye for my plastic 3D printing service for now. Expensive though.
Old 02-21-2011, 05:06 PM
I don't think the resolution for the Makerbot is anything close to Redeye.
Old 02-21-2011, 05:41 PM
giz giz is online now
giz is on a distinguished road
Also consider that these 3D printers have heated beds to keep the part from warping due to inconsistent cooling.
Old 02-21-2011, 05:55 PM
I saw that. They also sell a heating plate. Should be easy to make as well. I think that the hardest part would actually be the software. Seems that the ReplicatorG and Reprap software is specific to the motherboard.
Old 02-21-2011, 10:38 PM
RedskinsJBS's Avatar
RedskinsJBS is on a distinguished road
I think that RepRap has a Gcode generator... You just need to assign the extruder stepper as the fourth axis.
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
Old 02-22-2011, 12:01 AM
I read that reprap software can output to gcode. Then do I just put this into mach3 and my geckodrives will work?
  #11   Ban this user!
Old 02-22-2011, 07:22 AM
That should be the case. The Gcode simply creates spatial movement. Mach3 controls HOW that movement is translated in to the real world.
What I don't know is if the RepRap Gcode has any 'odd' pieces of code to it. As in, how does one control the temperature of the extruder with Gcode? You will have to d a little digging to sort that out.
  #12   Ban this user!
Old 02-22-2011, 11:41 AM
Jay C is on a distinguished road
I have built a Mendel 3d Printer and own a CNC router. A few experience based opinions:
1. I think yes you can use your CNC machine as a 3D printer. I have my layers set to .34mm (.013") so keep in mind how long a print will take
2. You don't need a heated bed if your use PLA (poly lactic acid is a bio plastic from corn) material. IMHO it doesn't stink like ABS so it's better.
3. Look at the Makergear stepper extruder. It's bullet proof.
4. You will need to have a post processor to convert the extruder commands to a 4th axis like a, b, or c. The software I use that generates the slicing and Gcode is called Skeinforge.
5. There are specific M codes that need to be implemented to control the extruder heater. M104 is the set temp. Not sure what it would take to get Mach to do this. I don't use EMC2 but I understand it does do this. Otherwise, you may have to use a micro to manage the heater. The extruder needs to be 190C to 220C depending on material and the job.
Hope that helps.
My machine can be seen printing here and photos of prints and the printer are here.
Converting a laser printer into a 3d laser printer Joćo Carimo General Metal Working Machines 22 03-08-2012 10:21 AM
Building a cnc router with an old printer and an old scanner codemaster Open Source CNC Machine Designs 13 07-31-2011 11:44 PM
New Machine Build- router/3d printer 1x0.7x0.3meter modular design watanabe DIY-CNC Router Table Machines 12 06-04-2011 09:58 PM
Converting a CNC router into a flatbed printer d_chappell DIY-CNC Router Table Machines 10 01-10-2010 11:10 PM
Printer for PCB ? WayneHill General Electronics Discussion 18 10-05-2005 12:42 AM
