Old 02-21-2011, 10:33 AM
george1965 is on a distinguished road
Which wire Gage
Hi guys
Can you tell me which wire Gage I should use to wire the gecko g540. I bought the whole kit from human design so I am wondering if I can can use the same Gage for relays , switches, power supply etc.all your help is appreciated.
Thxs
Old 02-21-2011, 01:26 PM
brtech is on a distinguished road
Motors: 20 ga. Don't skimp here. Shielded wire is good.
Relays and Switches: 22 ga, smaller would be okay. When we say "relay's" we mean the coil, not the contacts. Shielded wire is required
Power Supply: I'd try to get 14, but probably 16 is what fits on the PS to Gecko. I really would like to see the contacts for the power beefed up on the Gecko. I run 14 ga stranded, and cut off some strands to get it into the connector. 3.5A x 4 motors is 14A. Not for long, but you need 14ga wire for 14 A. If you use 16, make it short.
If one of your relay's is running the spindle at least 14 ga is needed on the contacts (assuming 10-12A motor). If your motor goes anywhere near 15A, you need 12 ga.
FARO Gage or Gage Plus SCmach2010 Want To Buy...Need help! 0 03-22-2010 06:19 AM
Faro Gage TURNING MAD Calibration & Measurement 2 05-04-2007 04:49 PM
Faro Gage TURNING MAD General Metal Working Machines 0 12-18-2006 11:25 AM
What gage wire? WilliamD General Electronics Discussion 12 02-13-2006 05:40 PM
#16 wire gage trubleshtr General Electronics Discussion 2 04-02-2005 07:09 PM
