Old 02-17-2011, 07:59 PM
HereinCS is on a distinguished road
Harmonic drive experts....help please
I'm considering building my own b/c axis. The Doughty drive is great, but I'd like to be able to use a larger motor. New harmonic drives are well over $1k each so I'm stuck at looking at ebay. I stumbled on this set. Would some one help me figure out if this would work? I figure the center piece goes into the piece on the right. Where does the piece on the left go into? How would I go about attaching a stepper motor to something like this?
Thanks in advance.
Jim.
Name:	eBay Image Hosting at www.auctiva.jpg‎
Old 02-17-2011, 09:31 PM
jjacstcy is on a distinguished road
I believe the piece on the left (wave generator) goes into the piece in the middle (flexspline) then they both go into the piece on the right (circular spline). Motor attaches to the piece on the left.
Old 02-17-2011, 09:34 PM
Have a look at this YouTube - Funktionsprinzip: Harmonic Drive Getriebe
Old 02-17-2011, 10:06 PM
Thanks jjacstcy. Great video. Though I still have some questions.
1. with this unit, how does the motor shaft get coupled to the wave generator?
2. I assume the piece that I'll be rotating with this unit fits onto the middle piece, how much weigh can it handle?
Old 02-18-2011, 05:02 AM
I am no expert but I think there is a piece missing. There should be a piece that gets pressed into the wave generator, that is where your input shaft goes. Your output shaft connects to the circular spline.
Old 02-18-2011, 06:16 AM
PBr PBr is offline
PBr is on a distinguished road
Or you have to make that missing part by yourself
Also what's the max. input RPM for such an transmission?
Old 02-18-2011, 09:28 AM
CarbideBob is on a distinguished road
Its a hollow shaft unit. Hole is for wires or piping to go through.
How much weight will it handle?
None, its a component set not a mounted unit. You need to build your own housing, mounts, and support bearings.
Google the Harmonic Drive website and download the catalogs, You'll find mounting examples and engineering info there.
Bob
You can always spot the pioneers -- They're the ones with the arrows in their backs.
Old 02-20-2011, 11:01 AM
Thanks for the advice. I've browsed through the catalog, but can't quite understand how to mount and drive these things. I've decided to buy a couple of different types to learn on. Luckily they were not too expensive. I'll probably have a million more questions once they arrive.
Thanks again.
Old 03-01-2011, 07:39 PM
My ebay harmonic drive just arrived. There is significant resistance and cogging when I rotated the drive. Is this normal or is it supposed to spin like a ball bearing?
Old 03-02-2011, 10:13 AM
giz giz is online now
giz is on a distinguished road
I don't believe that is normal. My two behave more like bearings, like you mentioned.
  #11   Ban this user!
Old 03-02-2011, 12:24 PM
NEATman is on a distinguished road
HereinCS-
It should rotate freely. It is likely that you HD unit is in a "Dedoidal" position. Take a look at page 12 of this PDF for an explanation:
http://www.harmonicdrive.net/media/s...hg-catalog.pdf
You should simply remove the ball bearing piece first (the wave generator), the remove the flexible spline from the circular spline. Replace the flexible spline into the circular spline making sure that there is equal clearance on either side. The flexible spline will only engage the circular spline at the maximum diameters of the elliptically shaped wave generator.
While you have it apart, you could clean the teeth, clean the ball bearing, and re-grease ti with fresh grease to ensure that there aren't any particles of stuff in the bearing area.
Keith
  #12   Ban this user!
Old 03-02-2011, 01:03 PM
Thanks for the advices. I think I had it a bit off center, it's rotating more freely now. I still feel a bit of cogging, but it's not too bad.
I guess my next question would be how do I mount a table to it without the gear falling out?
Is this a harmonic drive? HereinCS DIY-CNC Router Table Machines 4 02-14-2011 01:06 PM
harmonic drive helps confusion Mechanical Calculations/Engineering Design 3 09-10-2007 04:29 PM
harmonic drive, max RPM stepper or servo Art Ransom Mechanical Calculations/Engineering Design 5 12-11-2006 10:26 PM
Harmonic Drive juzwuz Mechanical Calculations/Engineering Design 13 12-03-2005 01:28 AM
Harmonic drive - keeping position? medved Mechanical Calculations/Engineering Design 1 11-30-2005 06:49 PM
