Old 02-11-2011, 04:53 PM
Justin Cavender is on a distinguished road
FLA 100 Machine definition
I just ordered an fla100 and was wondering if anyone had a machine definition for mach3 that they would give me?
Old 02-11-2011, 09:01 PM
CNC Lurker's Avatar
CNC Lurker is on a distinguished road
Did you get the 3 Axis Electronics Kit? Simply download the G540 Software Configuration File (XML) for Mach here: Gecko G540
You'll also want to read the G540 Manual, G540 Initial Setup Guide, etc. on there too.
http://paul-flores.com/
Old 02-12-2011, 07:05 AM
jason75 is on a distinguished road
I am about to order the FLA100 also. I plan on using Mach3. I am trying to decide what cad/cam to use. I have access to solid edge at work. Anybody know what cam might go good with that. Or what affordable "easy" cad/cam would work?
Old 02-12-2011, 10:56 AM
brtech is on a distinguished road
Depends a lot on what you want to do.
Lots of folks find that LazyCam is good enough for them. It's free with Mach.
A whole lot of folks like the Vectric products. Cut2D is the starter program, but VCarve Pro is what really shines for many.
Sheetcam has a lot of very nice features, and is a really good basic CAM.
I'm partial to CamBam. It seems to have everything I expect in an inexpensive CAM product, and is evolving in a good direction IMHO.
Old 02-13-2011, 01:54 PM
CNC Lurker's Avatar
There are many cam packages ranging from free to a few $thousand. Affordable is the key word. What do you plan on making? If you plan on making 2.5D stuff, Mach 3 comes with LazyCam. A step up could be CamBam Plus or Vectric Cut 2D (both $150).
The above can open a 2D DXF file too make your g-code.
Cut 2D Link
After looking at the screenshots, Cambam Plus looks like it can do 3D (such as the horse on that page):
Cambam LINK
For 3D, Vectric Cut 3D is $300, and VCarve pro is $600. These can import 3d .STL files. Some really love the Vectric stuff, others say it is too simple or limiting.
Machine Definition Doesn't Change Code? PrecisionD Mastercam 7 02-13-2011 01:31 PM
Machine Definition help drupillow Mastercam 0 04-23-2010 06:04 PM
Need Help!- Machine Definition setup jimmy996 Mastercam 3 03-24-2010 10:12 PM
Newbie- TL-2 machine definition for Mastercam jefffalk Haas Lathes 3 06-23-2009 06:40 PM
Machine Definition rrbmachining CamWorks 1 02-20-2009 05:04 PM
