Old 02-11-2011, 06:51 AM
mlk1950 is on a distinguished road
Cut Depth
Just did a couple of test carves on my new home built machine. What would be the most likely thing or things to look at, that would cause this?
1/2 and 3/8 x 10 single start screws
Dumpster leadnuts
305oz. steppers
Mach3
1/4 stepped
Thanks Mike
Name:	May 29, 2010 001.jpg‎
ID:	126219   Click image for larger version
Name:	May 29, 2010 003.jpg‎
ID:	126220   Click image for larger version
Name:	May 29, 2010 004.jpg‎
ID:	126222   Click image for larger version
Name:	May 29, 2010 005.jpg‎
Old 02-11-2011, 06:58 AM
vger's Avatar
vger is on a distinguished road
Z Axis, Missing steps? Loose coupling on screw? Can you post a pick of your Z axis?
Old 02-11-2011, 07:08 AM
mrgraphic's Avatar
mrgraphic is on a distinguished road
Loose set screw?
Could be loose set screw on spud shaft to belt drive gear. Use locktite
Old 02-11-2011, 08:16 AM
I just noticed a slight amount of play on the carriage to gantry. Will tighten that up and see.
If it is loosing steps on the Z, do I need to back off the Accel or the Velocity to remedy that?.
Got to go to work, be back later. Got to make some money so I can feed my CNC obsession.
Thanks Mike
Old 02-11-2011, 07:52 PM
Haven't had a chance to retest my machine yet, but I do have another question. Should the velocity and accel in Mach3 be set the same in all 3 axis? Or is it common to set them up different for each axis? Just trying to learn as much as I can about this.
Thank's Mike
Old 02-12-2011, 11:17 AM
crane550 is on a distinguished road
Set your velocity up to suit the needs of each individual axis. You wouldn't limit the speed of each axis to the speed of your slowest axis would you?
I take it you just got your machine going. You WILL run into problems like this at first. I did do. My first few cuts looked TERRIBLE. I was certain this whole CNC thing was a mistake, and I had just wasted a lot of money. But keep at it, ask questions, and you will get it going, and you will be amazed at what a machine like this can do.
Do you have a build thread? Would love to see it.
Looks like a Solsylva? Check out my thread, I did a lot of upgrades to the original Solsylva design. I will be more then happy to give you G-code for better bearing blocks and such.
Alex
http://www.cnczone.com/forums/diy-cn...a_build_w.html
Old 02-12-2011, 01:10 PM
Alex
Yes it is a Solsylva. It's been quite the experience, and loved every minute of it. I'm running the HCNC pro board with the 305 steppers. Here's a couple more pics. I'll welcome any suggestions or critiques you have to offer.
Thank's Mike
ID:	126324   Click image for larger version
Name:	May 29, 2010 015_RS.jpg‎
ID:	126325   Click image for larger version
Name:	May 29, 2010 016_RS.jpg‎
ID:	126326   Click image for larger version
Name:	May 29, 2010 017_RS.jpg‎
Old 02-12-2011, 02:47 PM
vger's Avatar
Mike,
Looks pretty good Mine started in the garage too... then built a workshop in the back yard (12' X 20') to put it and my other stuff in cause my wife thinks the garage should be for cars....
I set my X and Y for max of 60 IPM and the Z at a max of 20 IPM. I have a 4th axis (rotary) that can be set in the A, B or C axis that is set at 1200 degrees per min (20 deg sec) to do turnings with.
One of my earlier projects was a full set of alpabet blocks for the grandson. They are 2" cubes of hard maple with the letters and numbers all raised like the standard old blocks. I attached a zip with all the files for them if you want. Use a 1/8" dia bit with the Z zeroed at the top surface, and the X & Y Zeroed at the lower left of the block.
Steve
PS, cut the letters in the end grain of the wood.
Old 02-12-2011, 03:06 PM
Thanks vger, maybe that's part of my problem. I'm running my Z at 40IPM, I'll try to slow that down and see if that helps. I went over and was reading Crane's thread and what I decided to use on my X rail and gantry supports was 1 3/4" poplar. It's in between oak and pine for hardness and stability. A friend has a cabinet shop and we ran them through the thickness planer and joiner as to make sure they were absolutely straight. So far they have worked very well. Now just have to learn as much as I can and get her fine tuned.
Old 02-12-2011, 08:10 PM
My first son was just born this last December. He will be able to start playing with blocks soon, looks like I got a new project!
  #11   Ban this user!
Old 02-12-2011, 10:15 PM
I'm running mine fairly slow. The max I've ran it at was 40 IPM. What do you think a safe speed would be to shoot for. I'm planning on putting dampners and limit switches on in the future, cuz I'm only running the single start 10 acmes. Eventually I plan on upgrading to 8-2 starts.
  #12   Ban this user!
Old 02-12-2011, 10:36 PM
I am running 1/2-10 single start right now. My X is running 55 and Y at 60. I could probably push it more but I have not yet. I only been running the ACME rods for a few days. I managed to cut mahogany today at those speeds using a 1/2 bit taking .175 per pass. Worked flawlessly.
I have 1/2-10 5 start on the way for the Y. My Z is currently using 1/2-8 2 start, which will retract the router at 160 with no problems. Could probably go faster, but it's hard to jog and zero much faster then that.
Are you running anything else electronics wise on your machine other then the Pro board? Limit switches, and E-stop are still on the to do list.
Also, I am curious about the photo with the jumpers running on your board. Did you modify your driver?
Max Cut depth WilliamWoodWork WoodWorking 2 10-05-2010 10:46 AM
Problem- x4 Contour and Depth vdauer Mastercam 2 01-13-2010 10:32 AM
Newbie- Lathe cut depth MadPickinSkills General Metal Working Machines 3 10-19-2009 01:02 AM
What RPM/Depth of cut? sp1nm0nkey General Metal Working Machines 4 04-07-2007 10:45 PM
Npt Depth ryanduc General Metalwork Discussion 5 06-23-2005 04:24 PM
