Old 02-10-2011, 05:00 PM
HereinCS is on a distinguished road
Is this a harmonic drive?
Does this look like a harmonic drive?
DNS HEAD, GEAR 2-39-54857 - eBay (item 150519042369 end time Mar-11-11 11:34:40 PST)
Old 02-12-2011, 11:28 AM
jsheerin's Avatar
jsheerin is on a distinguished road
Looks like it - there seem to be teeth on the outside of the cup in one of the pics, but it's tough to tell for sure. I wouldn't buy it for that much money unless I could find specs on it to know what the allowable torque is.
CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
Old 02-14-2011, 05:14 AM
martyxxx is on a distinguished road
Yes it is, but according to part number it seems to me that it is size 11, 1:50 ratio component set and size 11 is very, very small - around 30mm in diameter. Ask seller if you want be sure. If you plan to use it for fourth axis, look for size 20 and bigger... Look here: Products | Component Sets | CSF Series Gearing Components :: Harmonic Drive LLC , there are similar ones.
Old 02-14-2011, 09:07 AM
Thanks guys. I was hoping for a bigger unit. Harmonics LLC quoted me at over $2k each! Guess I'll keep looking on ebay
Old 02-14-2011, 01:06 PM
giz giz is online now
giz is on a distinguished road
Keep in mind that you'll likely want a gear head rather than a component set. You'll have to add your own bearing if you go with the component set.
harmonic drive helps confusion Mechanical Calculations/Engineering Design 3 09-10-2007 04:29 PM
Home Made 4th Axis with Harmonic Drive Unit! widgitmaster Benchtop Machines 30 06-05-2007 11:14 PM
harmonic drive, max RPM stepper or servo Art Ransom Mechanical Calculations/Engineering Design 5 12-11-2006 10:26 PM
Harmonic Drive juzwuz Mechanical Calculations/Engineering Design 13 12-03-2005 01:28 AM
Harmonic drive - keeping position? medved Mechanical Calculations/Engineering Design 1 11-30-2005 06:49 PM
