I'm looking at building a small mill/router with the intent of milling PCB's almost exclusively. I'll probably make some small plastic parts and whatnot as well, but as mentioned, it will be primarily for PCB's. I have the electronics covered, so I'm just working on designing a machine. Pretty much I just need to find some affordable rails and bearings, but I'm not too sure what I require even. I'm wanting 12" rails for both the X and Y axis (makes things easier for me, long story), and then 6" rails for the Z axis. I was originally looking at the linear rails/pillow blocks on Glacern, so those are an option. I also ran across THESE eariler, which look quite interesting. Also looking at Hiwin (or other) square rails, which would be nice as well. So basically, what's the smallest rails that would be advisable to go with on a machine this size, and where are some places that have them readily available for a reasonable price? I'm a student, so money is somewhat tight ![]() Thanks, - Jesse |
| Jesse B The anodized aluminum rails are good, But have a little to much clearance in the bearings, they do have ajustable bearings for them, but are still not a good choice for CNC, those rails/bearings look like Igus being sold by another company The Hiwin is really the best, for your machine build 15mm square rails would be ideal, 12mm would be ok to, it depends on your design, For round supported rails nothing less than .625 or 16mm, You can of cause use bigger as well You can see my build here,I will be starting a small machine build soon http://www.cnczone.com/forums/cnc_wo...ld_friend.html
__________________ Mactec54 |
![]() Probably the best price around for new rails and bearing blocks. With immediate availability. eBay for used items on a hit and miss basis as far as quality and availability of required components, but good deals can still be found. Hope this Helps and Good Luck with your build. |
| I often pick up junked printers and scanners at the dump, free! They are a great source of precession rods and bearings / bushings not to mention stepper motors. Great for building a PCB router on the cheap.
__________________ Deeds not words... VoltsAndBolts Alternative Power Forums http://www.voltsandboltsonline.com/ |
| Awesome, thanks a lot guys for the suggestions. I've got a bit of shopping around to do (not that I can afford to right now ).Anyways, a tad off-topic, but here's what I've thrown together so far tonight. Still needs lots of work, and the majority of the details have yet to be worked out. |
| Hi, I built a machine with Igus rails and bearings, the plan was to mill plastic’s and also PCB’s (if I can work out the software), as of now I’m very happy with the results. ![]() More pictures if you like. http://www.cnczone.com/forums/diy-cn...y_machine.html |
#11
#12
I happened to talk to one of the igus guys today. I originally had him quote some DryLin SLW series slides. For a 21x19x8 machine, they came back with about $750. ![]() After I talked with him about my application, which is very similar to yours, he recommended the W series to me. It would still be around $90/axis + Screws and End Blocks for my size machine. Also, Jesse, I think I have decided to either buy a cnc or purchase these rails. So if you still want those THK rails from KTP, they're all yours (as long as his offer is still out there). I haven't heard anything from him in a couple days, so I don't know what's up. |
| Need Help!- Finding small PCD Countersinks | Scheer | Composites, Exotic Metals etc | 1 | 02-25-2011 11:28 PM |
| Need Help!- Finding small cheap CNC mill in UK | Xye | Benchtop Machines | 19 | 12-30-2010 04:51 PM |
| THK RAILS AND BEARINGS | clembrant | EBAY ADS | 2 | 10-07-2009 11:24 AM |
| Linear Rails and Bearings | Robyn | Product Announcements & Manufacturer News | 3 | 08-30-2006 10:10 AM |
| Will this spindle work for a small CNC mill? Not angular contact bearings... | Joel Elliott | Benchtop Machines | 1 | 04-17-2006 12:20 AM |
